09-09-2022, 11:25 AM | #1 |
Drives: 2017 Camaro Lt V6 Join Date: Jan 2020
2019 OEM rims fit a 2017 Camaro LT?
Hello guys hope everyone is doing well! So when it comes to rims, tires, offsets, I can't seem to wrap my head around it. So I'm in the market for new wheels for my 2017 Camaro LT. I found these wheels from a private seller and they look pretty nice and the tires have a good life on them still. My question is, will these 2019 OEM wheels fit my camaro without the need of any mods, spacers, etc. Attached are my wheel specs and the wheels I would like to purchase. Thank you all for your time and help.
09-09-2022, 11:37 AM | #2 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
They will fit. They look like 20-8.5 , 25 mm offset.Same as my 21 Camaro v6 rs factory wheels .
09-09-2022, 11:42 AM | #3 |
Thank you so much for the feedback! I was nervous since mine are 18in and these are 20s. I read on a forum on here that sometimes the speedometer is a bit off when wheels are swapped. Would I have to recalibrate it? I belive they said the tool needed could be bought on Amazon. Or maybe it was the tpm sensors? I'm so dumb when it comes to this that's why I'm so grateful for you guys. Thank you again for the help
09-09-2022, 12:06 PM | #4 |
Your 18" tire will be same height as 20" tire , your car will not know the difference. It will give a little wider stance. Worth doing in my opinion.
09-09-2022, 12:24 PM | #5 |
Thank you again you've been a huge help! I'm gonna pick these up. Gotta love the camaro community!
09-09-2022, 12:40 PM | #6 |
Post before and after pics.
09-09-2022, 12:49 PM | #7 |
I definetly will thank you
09-09-2022, 11:06 PM | #8 |
Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
very nice wheels.
09-10-2022, 04:00 PM | #9 |
They look like square set lt1 wheels . I think I like them more than my v6 rs wheels. Envy
09-10-2022, 05:40 PM | #10 |
376 cubic inches of fun
The wheels will fit. As for the speedometer question, be sure you get the right tires to match the diameter of your current tires. These will be the size tires that are OEM for Camaro with 20" wheels.
09-11-2022, 09:23 AM | #11 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I have the LT2 RS with factory 20s 245/40/20 square set up and purchased a set of 2022 SS rims staggered 8.5 front and 9.5 rear and run 245/35/20 and 285/30/20 and have no issues. The speedo is off but you can search "tire size calculator" and input sizes and it will tell you how far off your speedo with be. I run the square set up in the winter and staggered set up during the summer for track days so I didn't mess with recalibrating but I did buy a tire pressure learning tool.
09-12-2022, 03:39 PM | #12 |
Quick update guys so the rims did fit my camaro BUUUUT I have no room to turn. Not gonna lie the car looks amazing. So I took them off and will be taking it to a guy that will be i believe he said swapping out the struts so they fit and I can use them. I'll be posting pics of the tires and my car soon just waiting for it to be nicer. Hasn't stopped raining here in Chicago.
09-13-2022, 11:42 AM | #13 |
That is strange. The tires should be the same height ,25.7", and stick out 7 mm further. 32mm offset vs 25mm.
09-13-2022, 11:30 PM | #14 |
When I get off work I'll take pictures of my rims and tires and the ones I just bought. Maybe the guys that were gonna install them didn't know what they were talking about but in fear that I might damage them or put myself in danger I decided not to have them mounted. Might play with then this weekend and do it myself and try a test run.
