In car video of Maggie gettng dialed in on thpsi Port Injection
Well we made it to the Ls Fest with no issues. Got checked in and made it back to the hotel. Mike made it in from Cali to wire the PI and controller. Got it fired up after about 1.5 hours on the install. Then he worked on the tune since he basically had already made the file for the PI. He made 4 or 5 runs on I65 and logged those runs, he came back and made some changes after each run. We were on E72, Low side was 72 psi, 24.5 degrees of timing shifting at 6300 rpms with boost right at 8.8 psi. He said the car rips like a freight train and we will see if the train can rip down the track tomorrow. He thinks its probably making 640 rwhp and hopefully run 10.50 or quicker if it will hook. Later tater, got to get some sleep, up at 6 and to the track at 7 am with first passes starting at 9.
https://www.facebook.com/10002269009...45175025849499 Last edited by laynlo15; 09-11-2022 at 08:47 PM. |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
That sounds great! Glad to hear everything worked out just in time. Good luck at the race and enjoy the weekend with your new rocket!
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
Thanks, we sure hope all goes well this morning. No car with this PI has been down the track yet so we will give it a little hell and maybe more later.
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
FANTASIC !!! sounds great. Thats some good fuel pressure right their. I hope it hooks and books for you. Great work Mike I will be placing my order soon!!!
Thank you Al Oppenheiser!
Let 'er rip!
Looking forward to see what you all do |
That seems like an awful lot of timing for a LT1.
#7 |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
#8 | |
Either way this was supposed to be a conservative build and it's already set on kill. lol
#9 |
I think Mike has a real good idea what he is doing!!!
#10 |
Nope we are good, logs are great and went 10.34@135 w/1.50 60 ft. I left the traction control on accidently or it probably would have went in the 10.20s. Port Injection is awesome, doing that with just the additional JMS and keeping the pressure up was stellar. Second pass I turned all the nannies off and it didn't hook. One more pass today. No good air here today either. Right now we are 2744, my second pass it was about the same and first pass it was about 2000 DA.
#11 |
That's a great pass.
The thing with E is that it's hard to get it to knock. Are you guys reading plugs?
#12 | |
PS: congrats laynlo, I knew you would be knocking on 9s. This ain't your first rodeo. |
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
This project sure has a positive outcome. That time and MPH is nice especially at almost 9 psi. Have fun tomorrow!
How happy are you with the new setup?
#14 |
![]() Drives: 2019 Camaro 2SS Join Date: Aug 2020
Awesome man! It’s be interesting to do a $$$ study between what I did and what the PI cost. I think I had a little over $4K in LPE Pump/+30 injectors. However without a cam I can’t turn it up too much more. Sky is the limit for you when you really want to turn it up. $$$ difference will really benefit PI at higher hp levels. Very nice!
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
