Plugs/Gap - Modified LT4s
When I changed to this blower, I also changed to NGK 6510, w/.028 gap.
I'm wondering what others here have done for new plugs/gap?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I'm running Brisk RR14S @ 0.029 with a TVS2300 @ 14-15 psi
Petro-sexual
Not as modified as a lot of you, but running, as suggested by JRE, about .040" and around 15-16-psi. Running 1-step colder NGK Iridium for now. Might go down one more step to see how he likes it.
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I also use the NGK 6510, gapped to 0.035 at 17psi boost.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 Last edited by swisstyphoon; 09-07-2022 at 06:40 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I too am running the Brisk at 14-15 psi boost
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
Stock LT4 is 0.030, not sure why you'd go that much larger, in fact some brands wouldn't want you to open them up that far.
#7 |
Drives: 21 ZL1 Join Date: Feb 2022
6510 NGK LTR7IX IRIDIUM
#8 |
I agree and I wanted to see what others here are doing, I figured NGK would be popular and am not surprised about the range of gaps posted so far 0.028 - 0.040. Such larger gaps scare me.
2020 ZL1LE A10.
#9 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
.028- .031 is a great nominal range to run plugs on boosted applications due to the excess pressure that boost induces into cylinders. Any more than that and high boost levels equals spark blowout which would be bad news.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
#10 |
No, stock is 0.037 to 0.043
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#11 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
Denso ITV27 at their stock gap (~0.030). Good enough for 22 PSI from Mag 2650
#12 |
I'm with Ted on this topic.
Good explanation in this video https://youtu.be/G_DiTh8gQ6w Just like they taught us at mechanic school, your spark will be stronger with a larger gap. Because the Voltage is raising to jump the gap. But yes there is a point where your ignition system is maxed out, and the spark might not be able to jump the gap anymore with raised cylinder pressure. This is when you have to compensate the pressure by closing the gap. Ted said it well, you always benefit from running the max. POSSIBLE gap. For example. When I imported my ZL1 to Switzerland, after it just came from a performance shop in Florida it did not run well. Cutting out and stumbling. Lots of missfires, especially with every cold start. Turned out they gapped the new plugs to 0.027. Then I installed new plugs, gapped to 0.037 and it ran perfect after. Now after more mods, and higher boost / cylinder pressure, I closed the gap to 0.035. This is also what alot of big name tuners recommended for my setup. Not sure what boost you are planning to run, but if it is around 20psi I would say you are ok with that 0.029 gap.
2018 Camaro ZL1 A10
#13 |
My memory failed me on that one, the spec you have is correct for plug gap.
I do remember being on the dyno and having to gap them down to ~0.030" from ~0.040" or so once hitting around 15 psi on TVS2300. That's what it took to get the most power, timing, and no misfires to 7k rpm on my car. My car is running 93 with 50/50 water/meth (mostly for cooling and a little octane). It might be possible to go a little wider but not sure I'd find the benefit easily. I did find the Brisk plugs were much less prone to misfires, might be an opportunity to go wider and see. I'm not sure what fueling everyone is using and if running E blends changes the game here with gap.
#14 |
Dyno Show Queen LOL
NGK 6510 gap to .022 for me
