Old 09-05-2022, 10:34 PM   #1
Aquarius
Aquarius's Avatar
Drives: Rapid Blue 2022 Camaro 1SS
Will the 6-piston Brembo Big Brake fit inside 19" wheels?
Looking into upgrading all 4 corners of my SS with the Brembo Big Brake 6-piston calipers up front and the 4-piston calipers in the rear. I am, however, having difficulty finding measurements/dimensions for the brakes. Specifically, how much space does the new rotor and 6-piston caliper take up. A few months back I decided to get 19" wheels for my Camaro, and I am wondering if there is still enough space for everything to fit inside the slightly smaller diameter of the aftermarket wheels.
Any insight or experience from other owners would be helpful.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000
11/4/2021 - 3100 Status TPW 11/15
11/9/2021 - 3400 Status TPW 11/15
11/24/2021 - 3800 Status built 11/21/2021
12/2/2021 - 5000 Status
12/13/2021 - 6000 Status
Aquarius is offline   Reply With Quote
Old 09-06-2022, 02:12 AM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
If you have an SS, you should already have 4 piston calipers in the rear (they are smaller than the fronts but still 4 piston...)
Old 09-06-2022, 09:27 AM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
yes, even 18s will fit on 6 piston, 17 on 4
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 09-06-2022, 01:01 PM   #4
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
I still have 20's, so not an experienced user. But as MP3Boosted noted, the short answer is i think an unqualified yes, it will fit. note that the zle comes with 19's. Maybe some of the fellow track guys can chime in with experience, as many i have met run 19's or even 18's with the 6p fronts.
Sure there are other threads, but here's one from an experienced user who i know is running zl1 6p brakes up front.
https://www.camaro6.com/forums/showthread.php?t=604024
Eric10905 is offline   Reply With Quote
Old 09-06-2022, 01:27 PM   #5
Aquarius
Aquarius's Avatar
Thank you for the link to the thread. I must have been looking in the wrong places for information. Very helpful.
10/15/2021 - 2000
Old 09-06-2022, 01:47 PM   #6
Eric10905
No worries. btw, that rapid blue looks sharp. ;-)
Old 09-06-2022, 05:11 PM   #7
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Yep, I like that blue too!
Did all 2022 LT1's come with Chevy's new larger Brembo front brakes or was it an option outside of CA and WA for 2022?
If you have the "no copper Big Brake" option, the LT1 might benefit just as much with a change to aftermarket competition type pads as a complete swap to 6 pad Brembo's would... opinions?
See here- https://www.camaro6.com/forums/showthread.php?t=587671
Ventmaster is offline   Reply With Quote
