09-05-2022, 04:39 PM | #1 |
Drives: 2022 SS 1LE Join Date: Jan 2014
Ported zl1 throttle body on SS
Sold my 2017 zl1 a couple years ago and just picked up a SS 1LE, I have a ported Tony Mamo zl1 throttle body sitting in a box from my old car. Does anyone know if this will work on my SS or will it need a tune. Trying to decide if I should sell it or use it. Thanks
09-05-2022, 10:02 PM | #2 |
Drives: Rapid Blue 2022 Camaro 1SS Join Date: Sep 2021
not specific experience, but with just general experience: Anything you add to your SS without a tune will have nominal gains, if any. A tune will be needed to unlock any expected gains for any bolt-on upgrade. Also, if you upgrade your throttle body without upgrading any other parts of the intake side of your engine, the results, with or without a tune, will most likely barely be noticeable.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000 11/4/2021 - 3100 Status TPW 11/15 11/9/2021 - 3400 Status TPW 11/15 11/24/2021 - 3800 Status built 11/21/2021 12/2/2021 - 5000 Status 12/13/2021 - 6000 Status |
09-05-2022, 11:06 PM | #3 |
Drives: 2010 camaro Join Date: Dec 2017
i would sell it. Not worth the time and effort for the issues, since these tb's are gimmicky with electronics. By the way, how do you like the ss 1le over the zl1. Do you miss the extra power?, do you like the ss 1le more?, do you enjoy the simplicity of the 1le more?
09-06-2022, 05:44 AM | #4 | |
09-06-2022, 05:47 AM | #5 | |
09-06-2022, 07:02 AM | #6 |
Drives: 2020 LT1 Join Date: May 2020
Ive used the stock TB, a mamo V2, and the Soler. There is next to no difference with any of them, and my car is tuned.
Too weird to live, too rare to die.
09-06-2022, 08:18 AM | #7 |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
FWIW, i bought a used pray ported ZL1 oem TB in an SS a few years ago with no issues. I wouldnt be surprised if its the same GM part number.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
09-06-2022, 09:52 AM | #8 |
Will it work without tuning yes. Should you ideally tune for it yes...without tuning your idle timing will likely drop really low. The Larger throttle body changes how far open the blade needs to be in order to idle. Since these ECU controllers are torque base, the ECU will pull torque which lowers timing in order to hit target idle speed.
2016 NFG 1SS A8
