Old 09-05-2022, 10:49 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
AVOIDING HEAT SOAK... Brainstorm
Hey Guys... I'm sure you have all noticed... you park the car with an IAT3 of 120-140... you go back even 90 minutes later, and after you start the car, they are 160+
Although the cars do cool down fast when you start driving, I had an idea that I saw from my friends turbo Porsche.
I wonder if when the car is turned off... if the electric fan stayed on for 5-10 min, and the HX pump ran for 3-5 min... if that would help the longevity of everything under the hood after shutdown. When I park at home, I pop the hood to help with cooling down and almost everything even the plastic parts are too hot to even touch.
And if we thought that might help.... how in the hell could you program that?
Thoughts? I'd love to test / try it!
Old 09-05-2022, 10:53 AM   #2
Smokin19
Drives: 19' ZL1 A10, w/pdr
Doesn't some other foreign cars have this feature also, seems I have seen some doing this.
Smokin19 is offline   Reply With Quote
Old 09-05-2022, 11:00 AM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
I think you'd have to do something like the FII interchiller to eliminate it. Even with a water cooler like mine it will eventually get hot if driven on an extended basis
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 09-05-2022, 11:32 AM   #4
Z OH 6
Drives: 2024 CT5-V Blackwing
The Hellcat Redeyes have this function from the factory.
Old 09-05-2022, 11:59 AM   #5
SOCAL.M6.ZLE
that is bad ass... Seems simple enough, but im sure it isnt.
Need someone creative to figure this out
Old 09-05-2022, 12:07 PM   #6
Trochoidal
Drives: 2017 Camaro 2SS A8
Back in the early-late 90’s we did a lot of turbo/intercooler/fuel/spark/air upgrades on Conquest/Starion, Ecplipse, 300Z, and Supra. Nearly all of those cars, at some point, would get turbo timers from HKS. In a nutshell it accomplished cooling down these cars. Maybe not to ambient but a lot better than doing nothing. The goal was to give the turbo time to cool without promoting coking.
For what you’re after, the philosophy is similar.
Recent conversation about the Too High PSI controller makes me think something like this is ideal. (I can’t recall if that had 2 or 4 extra inputs/outputs. Also what units these extra inputs offer) Maybe not the exact component, but something similar minus MAF and piggy-backing the ECM.
You would need to have an input from the coolant temp sensor and an output to your fan. Set that desired temp and let it do the work. Have a 2nd input picking up IAT and have that output going to HX pump. Set desired temp and let it do the work. Of course all of this would be achieved with a key off scenario.
If I were to approach this on my own as a DIY I’d feel compelled to add separate sensors and not splice into the sensors the ECM is using.
Maybe something like this product. This may not work with key-off. It could be wired hot but that might also cause some sort a parasitic drain.
Lingenfelter TBRC-001 Temperature Based Relay Controller
https://www.lingenfelter.com/product/L460220000.html
Let the brainstorming continue!
Old 09-05-2022, 01:20 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
You can use the "ignition off fans" settings in the tune to control the main fans. Not sure about the HEX pump. It's probably in there if someone wanted to find it and get HPTuners to add it.
Mods being installed-
Old 09-05-2022, 01:35 PM   #8
Yup, here's what's available along these lines. This will only control the main PWM fan behind the radiator/intercooler, but even that should help already.
The default ECT threshold here is set pretty high at 225 °F, this is likely why the fan doesn't stay on for most people after killing the engine.
Old 09-06-2022, 05:08 AM   #9
SOCAL.M6.ZLE
hmmmm, thats interesting. Great find! Does anyone on here have the capability to test this?
Old 09-06-2022, 05:11 AM   #10
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
It works, to do any justice and bring intercooler loop down to a temp you'd like to see I hope you have a set of batteries you plan on plugging into the car Way too much thermal mass there to run the fans long enough to make it worth anything using the onboard battery.
I'm not aware of anything other than the pump On/Off control that is available in HP Tuners, nothing in that circuit uses temperature, it is on or not when the car is running.
Old 09-06-2022, 05:34 AM   #11
SOCAL.M6.ZLE
Makes sense... What is your opinion on a sweet spot for cooling / battery life? Maybe run the fan at 50% for 10 min?
Old 09-06-2022, 05:49 AM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Leave hood open and apply external snail fan.
Old 09-06-2022, 07:02 AM   #13
Joshinator99
Moderator
Joshinator99's Avatar
Ice tank will drop intercooler temps in a hurry… Just throwing that out there.
Old 09-06-2022, 07:40 AM   #14
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
exactly, you park for 90 min the IC coolant is in the motor 160 plus, start the car the trunk tank coolant is 100 (5 gallons plus) with in a min its lower even with no ice.
That's why it try to talk people out of the ADM and other small reservoirs that mount over the headers or on the cooling fan shroud. 1. there not big enough, and 2. the engine heat does them no favors.
a better IC pump also helps
