Old 09-05-2022, 05:17 AM   #1
smokingv6
Drives: 2019 SS 1987 GN 1972 442
Which handheld tuner should I get?
I own a 2019 SS all stock except muffler delete. I plan on installing a cold air kit and maybe throttle body spacer, considering the BULLY DOG BDX , or which one has the best bang for the buck? I want to be able to set it to stock at anytime since still under warranty, thanks
smokingv6 is offline   Reply With Quote
Old 09-12-2022, 08:48 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Chevy can tell its been flashed this back and forth thing is no longer a consideration, once you flash it, you're warranty is toast.
Old 11-01-2022, 09:51 PM   #3
Mantis-SS
Drives: Camaro SS
I went with the Diablo Trinity 2 EX Platinum. Ran the 93 octane tune for a while and then reached out to ******* tune. Did some data logging and had him send me a custom for my setup. I'm very happy with the results. Thats the good news, the bad news is if I ever decide to add long tubes he'll tune it but he won't do anything about the check engine light.
Mantis-SS is offline   Reply With Quote
Old 11-01-2022, 10:02 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Virtually every LT tuner uses HP Tuners. Works great whether your build is mild to wild.
