09-01-2022, 12:03 PM | #1 |
Drag wheels and tires
Hi forum folks. Looking for the best set up for my 2014 2SS. Looking for rear drag wheel and tire combo. running stock rear end and 6 speed manual trans. Tried race star 92 17" wheels and they won't clear the Brembo brakes. Does anyone make an 18" x 11 wheel? would appreciate any feedback on what the best set up would be. Radial or slicks? won't be driving this combo on the street. Making just under 700 HP on E85. Thanks for your help.
09-01-2022, 11:38 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
17" Dark stars for my car. What is it hitting on yours? There's a lot of us using those
09-02-2022, 11:15 AM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
18 dark stars with 315-45-18 555rII
22% lower/ 2.5 upper/ 2 headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5 intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2 lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
09-03-2022, 05:21 PM | #4 |
Man, those look killer!! And the car..
09-03-2022, 09:18 PM | #5 |
09-06-2022, 06:52 PM | #6 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Forgestar f-14 17’s . 18’s front skinny’s they clear my calipers . Running 305/45/17 MT street et R’s fronts are 28x6 MT sportsman’s .
Had to tie back e brake cable , they looked like they wouldnt rub but ended up getting alittle chaffed so I tied them back .. Night and day difference in traction coming from 20’s to 17’s in the rear .. Couldn’t get traction at all when I hit the skinny pedal with my stock rims , had bfg’s comp 2 A , not to sticky if a tire but I immediately jumped to my 17’s and they hook! Almost made it not as fun as sliding all over the place lol
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 Last edited by Risingson05; 09-06-2022 at 07:47 PM. |
