09-01-2022, 05:37 AM | #1 |
Drives: 2021 Chevrolet Camaro SS 1LE Join Date: Dec 2020
Difference between standard and drag strip launch control?
Based on a chart I found (see below, I don’t remember where I found it), using launch control in Race Mode indicates “Drag Strip” launch control is active whereas in all other modes it indicates “Standard” launch control. I would think any time you’re using launch control it would be a drag strip situation. What is the difference between the two??
Vehicle is a 1SS 1LE with a 6 speed manual transmission. Last edited by KARMAL; 09-01-2022 at 07:35 PM. |
09-01-2022, 05:55 AM | #2 |
Drives: 2022 camaro 2ss 1LE Join Date: Dec 2021
I know you can adjust the amount of slip percentage and rpm launch in race mode, I dont know if it applies to the other ones, Ive only used it in race mode.
09-01-2022, 11:19 AM | #3 |
I believe you can only do that on the ZL1. I don’t see an option for that on the SS, unless I’m missing something? Or maybe that’s unique to the 2SS?
09-01-2022, 12:12 PM | #4 |
Drives: 21 ZL1 Join Date: Feb 2022
Best bet get a real DR on the back. And turn it all off. Then just stab it from idle. Or you can load up the converter a tad to keep the driveline snap lower to prevent something sheering off.
09-02-2022, 03:15 AM | #5 |
Not sure if its unique to the 2ss or not, but its there. Ive used it a few times.
