Old 08-30-2022, 06:38 AM   #1
mliebs
mliebs's Avatar
Drives: 2022 ZL1
2022 ZL1 oil pressure question
I have a 2022 Zl1 with 1600 miles on it and just had the oil changed. The before and after oil pressure is the same but compared to what I'm reading in these threads my pressure seems to be quite a bit higher than a large majority of others. At hot idle it sits right at 39-40 psi and at 16-1700 rpm's it's cruising at 51-52. I put it to about 5000 rpms for a couple seconds and the pressure was around 60 or so. I haven't been WOT yet so I'm not sure where it will be. Does anyone else have higher pressure like this?
mliebs is offline   Reply With Quote
Old 08-30-2022, 07:13 AM   #2
Xelor
Drives: 2022 ZL1
You have the new upgrade oil system in the 2022 model.
Major failures in the past years. GM upgraded
Xelor is offline   Reply With Quote
Old 08-30-2022, 07:33 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
What oil did you put in it?
Old 08-30-2022, 07:34 AM   #4
raptor5244
Drives: 2022 CT4-V Blackwing
Sounds normal. ~35-40 hot idle, ~45 cold idle, ~60-70 at WOT.
If you starting seeing it dip to like 20psi or so while idling then you know you have an issue.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 08-30-2022, 07:40 AM   #5
mliebs
mliebs's Avatar
Drives: 2022 ZL1
Good deal thanks. I used 0-40 supercar
Old 08-30-2022, 10:59 AM   #6
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
What is this statement based on?
ZX-10R is offline   Reply With Quote
Old 08-30-2022, 02:02 PM   #7
raptor5244
It is based on Fake News.
2019 Tesla Model 3
Old 08-30-2022, 04:17 PM   #8
ZX-10R
ZX-10R's Avatar
How do people just pull stuff like this out of their azz and hope it sticks?
