![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
BENEFITS of long tube headers on a Supercharged setup
I know this topic has been brushed on over the last 5 years.
*factory exhaust is efficient to over 650whp *better things to put your $ towards Etc, etc What about Heat dissipation from the engine bay ? Anyone have data showing lower underhood temps post headers on a supercharged setup ? Last question: Any before and after dyno of headers on a supercharged setup ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
Headers will increase heat under the hood unless you thermal coat or wrap them.
The factory cat pipes are the biggest bottle neck. One member went from factory headers with new era cat deletes to catless headers and gained 19whp on a 650-670whp Whipple setup.
We checked my green cats last week and they were burnt/mangled, so we scraped them out. It now has only the Kooks AB mufflers.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
not surprised...only the gesi gen 2 cats seem to be holding up on higher horsepower fi builds.
#5 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
Moderator
It really depends on your power level as the OP touched on. As you crest 650 WHP you’ll start to see soaring OEM cat temps and less efficiency from the engine. That’s about the point where you should seriously consider headers & high flow cats (or no cats… for off road use only, since the EPA is probably reading this
#7 |
Very good info
Yeah definitely getting rid of cats either direction I take
16 1SS M6 White
#8 |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
Hey Asthmamax11,
We are neighbors and I love your setup. How are you going to deal with inspection? I'm in Gwinnett County. You can take it off-line and message me if you like but I'm sure you never plan to drive it on the road again after you remove the cats. I know the EPA is watching. I will go hug a tree while I wait for your response. |
#9 | |
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Consider this (more info below): Long tube coated (was already catless which netted me +23/+4), NW 103 TB and big gulp = +34rwhp & +23 tq. Alot of $ for minimal gains. ------------------- 2017 Camaro SS M6 (rwhp/rwtq) OS = Over Stock OP = Over Previous Setup Complete Street Performance / Dynojet Stock 417/428 Stock Tuned 429/440 +12/12 OS Whipple 3.50 pulley, LT4 HPFP, LT4 Injectors, RotoFab Dry, Stock exhaust w/ Cats 597/591 +180/163 OS +168/151 OP (stock tuned) Previous Plus: NEP Cat Delete Pipes (primary & Secondary) 620/595 +203/167 OS +23/4 OP Previous Plus: Borla Atak, Borla Resonator, Kooks 2” LTH coated, NW 103 TB, RotoFab Big Gulp, Granatelli Plug Wires, Gforce AL DS, DSS Axles 654/618 +237/190 OS +34/23 OP ***This step was very costly and yield little results for the $ spent*** Retuned by EFX/Mustang Dyno 688/632 I went and got it retuned by EFX after talking to them about the bog issue and the torque management. Also there was a rough/weird spot down low i didnt like. Both were taken care of. Perhaps I could next look back and try and match up best 1/4 mile on each setup.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
#10 | |
Moderator
#11 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I am not supercharged; just a 2017 SS with Kooks headers and cats. But the benefits of headers on a supercharge engine will be the same or likely better.
On the stock manifolds and cats, my car made 393 peak WHP and 416 peak WTQ. With 1 7/8 headers and cats and on the same dyno, it made 421 peak WHP and 408 peak WTQ. So gained 28 peak WHP and lost 8 peak WTQ. But... The significant gain was power and torque above 5000 rpms. Both HP and TQ were maintained much better from 5000 up the redline. At 6500 rpm before headers, WHP and WTQ were 355 and 280 respectively; after headers and at 6500, WHP and WTQ were 410 and 330. That is a gain of roughly 50ish WHP and WTQ in the upper rpm's which is amazing. That is equivalent to a cam swap. These engines just want to breath. |
#12 | ||
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 08-30-2022 at 08:52 AM. |
#13 |
Moderator
Definitely agree (and did the BG myself early on even though it was overkill). I was just commenting on JHunsbergers post that his TB/CAI mods were expensive for the amount of HP he gained, that’s all.
#14 | |
