Old 08-28-2022, 11:16 AM   #1
Geese1
Geese1's Avatar
Drives: 2022 2SS 1LE - 2023 Mazda3 Turbo
New crush washers for oil change?
Just a quick question. I'm going to be doing my first oil change soon, and I was checking on the parts needed, and I didn't see any mention of using a new crush washer on the drain plug. I've previously only had imported cars, and they always had you change the crush washer on the drain plug whenever you did an oil change, but I didn't see any mention of it here. Is this something that is needed, and if so, what is the correct size/part number to get?
Thanks in advance!
2022 Camaro 2SS 1LE - manual - Rapid Blue
*Black Wheel Lug Nuts and Locks Package
*Knee Pads, Black Sueded
4/15/22 - #1100
4/19/22 - #2000
4/22/22 - #3000
4/26/22 - #3000 - TPW 5/23
5/12/22 - #3400 - TPW 5/23
6/18/22 - #4300
7/25/22 - #6000 - Took delivery
5/28/23 - hit 1,500 miles - break-in officially over!
Geese1 is offline   Reply With Quote
Old 08-28-2022, 04:49 PM   #2
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
No crush washer.
The seal on the OEM drain plug is reusable. I've never replaced the seal on mine and still have no leak issues.
--KG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 08-28-2022, 08:19 PM   #3
Geese1
Geese1's Avatar
Originally Posted by KLG View Post
No crush washer.
--KG--
Thanks for the info! Any sort of maintenance/cleaning I should do on it before putting it back in?
4/15/22 - #1100
4/19/22 - #2000
4/22/22 - #3000
6/18/22 - #4300
Old 08-28-2022, 09:19 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
I haven’t replaced it either and it works just fine. Wipe off the bolt, pan and call it done.
Old 08-29-2022, 06:33 AM   #5
Geese1
Geese1's Avatar
Will do; thanks everyone!
4/15/22 - #1100
4/19/22 - #2000
4/22/22 - #3000
6/18/22 - #4300
Old 08-29-2022, 11:56 AM   #6
ctrlz
No crush washer.
Same here.
And on some cars (that require them) I've used brand new crush washers and still see small drips when I go back for the next oil change! And, yes, I wipe everything clean before I install and torque them.
I also have some cars where I reuse the old crush washers and have no leaks/drips.
From what I can tell, the aluminum ones work better than copper.
Old 10-05-2022, 08:31 AM   #7
Dave88LX
Dave88LX's Avatar
Drives: 2022 2SS 1LE 6 MT
Stahlbus drain valve...no worries about washers/seals now.
2022 Camaro 2SS 1LE
Rapid Blue || 6MT
Dave88LX is offline   Reply With Quote
Old 10-06-2022, 06:01 AM   #8
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I put Teflon tape on threads on washer side.
Gen6cyl is offline   Reply With Quote
Old 10-06-2022, 06:33 AM   #9
Dave88LX
Dave88LX's Avatar
Why did you put teflon tape on there?
2022 Camaro 2SS 1LE
Rapid Blue || 6MT
Old 10-06-2022, 11:36 AM   #10
Gen6cyl
I have always changed my oil , over 40 years. Have had cars that had a drip at plug and teflon tape stopped it. Easier , cheaper than new washers. Gives the plug a snug feel. Never had a leak or plug loosen when using it. Maybe good for the threads. Cheap insurance. I don't put tape on where threads will be inside pan.
Old 10-06-2022, 12:13 PM   #11
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
I'd be concerned that a piece of it will come loose and get sucked into the oil pickup. Most of that tape will be inside the oil pan.
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel
1937 Ford Slantback
Jus Cruisin is offline   Reply With Quote
Old 10-06-2022, 12:22 PM   #12
Gen6cyl
I reckon tape is 1/4" ,3-8" wide I go no further from washer. It's always there when I take it out albeit oily and squished.
Old 10-06-2022, 03:51 PM   #13
Why do you need a crush washer when the OEM plug has a proper rubber seal? I never had any leaks without a crush washer. Am I overlooking something?
Old 10-06-2022, 06:16 PM   #14
Gen6cyl
I'm talking over 40 years of changing my oil. I started using Teflon tape on a Mazda 3 that would drip.I know gen6 has a permanent rubber washer.I started using the tape on the Mazda and never stopped using it. Kind of safety thing like safety wireing bolts.
