Old 08-27-2022, 03:33 PM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Front Splitter Removal
Does anyone know if i can remove the ZL1 1LE front Splitter with the bumper on the car? When I did the conversion, i had the bumper off but i think the front lower splitter clips can all be reached and removed as long as I removed all the lower trays. Is that correct?
Today while having fun in the mountains, a huge rock hit my splitter. Fortunately, it didn't break it but it damaged my PPF and the gloss paint. So need to redo paint and PPF but I seriously do not want to have to remove the bumper.
Old 08-27-2022, 07:07 PM   #2
rbiehl
Drives: '23 ZL1 Riverside Blue M6
I removed and replaced the splitter on my 18 ZL1 without removing the bumper. I don't believe it would be different on the ZLE.
Sent from my SM-G965U using Tapatalk
rbiehl is offline   Reply With Quote
Old 08-27-2022, 07:48 PM   #3
Wuiquen
Wuiquen's Avatar
The ZLE splitter has push tabs under the lower grille. I know the side clips i can get to it. I am not too sure about the middle ones. I guess I'll find out soon
Old 08-27-2022, 08:15 PM   #4
rbiehl
Almost positive the ZL1 has the same plastic push connectors. It wasn't fun but I think you can get it off without taking off the bumper.
Old 08-29-2022, 02:48 AM   #5
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
I've got 10 inch race ramps if you want to bring it over to give it a quick look-see.
Also have all in one jacks stands that will take it further.
Lmk if I can help.
Mac7504 is offline   Reply With Quote
Old 08-30-2022, 08:15 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
1. peel back the fender liners
2. remove the 3 bolts on winglets each side
remove the push tabs on each winglet from the inside by going through the fender liner (push in safety tab then slide up or down depending on which direction its installed)
3. remove the hard plastic pan under the car 10mm bolts and 1 push pin
now remove the jillion 7mm headed bolts that hold the fabric material to the splitter and the 3 piece wind diverters. there's a chance you may have to drill out the 1 rivet in the center diverter some are push pin style some aren't.
Now fold down the fabric material to gain access to the same 2 clips found on each of the winglets.
I was the 1st to install this aero kit I've done it at least 3 or 4 times for local people.
https://www.camaro6.com/forums/showthread.php?t=508925
on your 1st attempt it maybe easier to remove the bumper if so see lethal garage's video its an ss but its the same except the splitter which I lined out.
Old 09-04-2022, 10:04 PM   #7
Wuiquen
Wuiquen's Avatar
Lmk if I can help.
Oh man i didn't see this in time. I did it today. On my driveway with two jacks. Now i need to get it repainted and re PPF.
Let me know if you want to go for a drive sometime. I usually go out to ACH or Ojai or SD
Old 09-04-2022, 10:06 PM   #8
Wuiquen
Wuiquen's Avatar
Thanks. Yeah this helped. The push tabs were easy.. the middle tabs that are pressed under the grill were a PITA but i got it done.. hopefully i won't have to removed again. This car has taught me to be more accepting and stop worrying about small damage.. it is inevitable for this car. Big rock magnet.
Old 09-05-2022, 07:04 AM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Most people have problems with pulling into far in parking spots and not backing in.
I have the rock problems even with xpel or ceramic clear bra that can't stop all rocks from cracking my carbon fiber splitter.
Old 04-17-2025, 11:40 AM   #10
Bruce88
Bruce88's Avatar
Drives: Chevrolet Camaro ZL1 1LE
Front Splitter Removal - Can't Get the Eight Center Tabs to release
I want to refinish my splitter so I removed the front bumper. I removed the locking pins from all the tabs that hold the splitter onto the bumper and the outside sections of the splitter are loose but I can't get the eight tabs in the center of the splitter to release from the bumper. Those eight tabs don't have the locking pins like the other tabs but it appears they have a notch that locks each tab into the bumper. I've tried to push the tabs to move that notch out of the way and tried to slip a putty knife in but I still can't get the center section of the splitter to release from the bumper. Appreciate any helpful input.
Bruce88 is offline   Reply With Quote
Old 04-17-2025, 11:48 AM   #11
clg82
Drives: 2020 Camaro ZL1
The only input I'd have for you is good luck with that, when those 8 are inserted it is damn near impossible to remove afterward. As you said there are no push clips for those, the locking mechanism is in the hard plastic itself. Save yourself some sanity and just buy a new one.
Old 04-17-2025, 12:22 PM   #12
Bruce88
Bruce88's Avatar
Appreciate your input but even if I buy a new splitter I'll still have to remove the old one. I wonder if there's a tool that makes removal easier?
Old 04-17-2025, 12:34 PM   #13
clg82
I believe if I remember correctly, when i did the 1LE front end conversion on my ZL1, i actually had to dremel those tabs off and remove them.
Old 04-17-2025, 12:56 PM   #14
Bruce88
Bruce88's Avatar
The dealer parts guy is telling me they're riveted on but I don't see any rivets. He's emailing me whatever he's looking at so hopefully I'll receive that soon.
