08-27-2022, 03:59 AM | #1 |
Drives: 2021 chevy camaro LT1 Join Date: Aug 2021
2021 Camaro LT1
Hey guys so I have 2021 camaro LT1 10 speed and I wanted to change the rear differential oil and trans oil and I can't quite find what kind of trans fluid will be the best for the car. Do you guys have any recommendations?
For rear differential oil I went with ACDelco GM Original Equipment 10-4034 Dexron LS 75W-90 Gear Oil For trans is ACDelco GM Original Equipment 10-9395 Dexron VI Automatic Transmission Fluid? I really wanted to try amsoil atf but almost every forum I read some say yes some say no only GM stuff. I would love to hear some suggestions Thank you so much |
08-27-2022, 10:24 AM | #2 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
As long as the oil meets GM specs, you're good.
I have royal purple in my M6 and GM in the rear. The only "sticky situation" is engine oil. It has to be dexos rated. Amsoil is supposed to meet that rating, but it isn't officially "approved" therefore it could void the warranty.
08-27-2022, 12:34 PM | #3 |
Drives: 2022 Camaro LT1 Join Date: Aug 2021
Trans fluid for the 10L80 is Dexron ULV PN 19352619, not Dexron V1
08-28-2022, 05:31 AM | #4 |
Thank you so much guys I was having so much hard time to find out what kind of oil should I go with
08-28-2022, 05:44 AM | #5 |
Also do you guys know what is the trans fluid capacity because I want to replace the oil I read this
Capacity: 10 speed With O Cooler 10L80 Total Fill 12 quarts. Capacity: 10 speed With Cooler 10L80 Total Fill 13.7 quarts. Capacity: 8.7 quarts Initial Fill. I am guessing the 2021 LT1 does not have a cooler so it needs 12 quarts? |
09-06-2022, 10:25 AM | #6 | |
Drives: 2022 2SS 1LE 6 MT Join Date: Aug 2022
So what else out there is "officially approved" aside from Mobil 1 ESP? |
09-06-2022, 08:46 PM | #7 | |
Dumb Ass Deluxe
If you drive like grandma 5-30 is good. If you like to drive hard, or race, I'd go 0-40. Amsoil is "supposed" to meet GM specs, but it isn't licensed so you might have a warranty issue if it ever gets down to it..
