![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
U18A2 Lost Communication w/ fuel pump driver
Any of you guys come across this code? "Lost communication with fuel pump driver control module". And the accompanying code P2635, "Fuel pump flow performance". I assume the first triggered the second. But, the P code showed up first in the DTC queue.
I just removed my JMS and installed the DSX low side aux pump. I had a little fun this morning putting to sleep a newer Corvette that looked like a ZR1 without the wing. Anyhow, I looked down at the dash and I notice the CEL. It did not do this when I logged a couple of runs the other day. I think I hit the rev limiter. I have a bad habit of watching the other car and not my tach. I have hit the limiter before and this has not happened. I cleared the codes and she runs fine. What do you guys think?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
#2 | |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Will do. Thanks.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
Hey Mike,
Do you know how to do that in TP Tuners?
Yea just set it to no error reported in hp tuners and reflash it.
#7 |
So, is the low fuel pressure DTC causing the Loss of communication DTC?
