Old 08-24-2022, 07:20 AM   #1
hawk02
Coupe Newbie
hawk02's Avatar
Intercooler Coolant Level
Yesterday I attempted to purge the intercooler system of air using a Dedicated Motorsports adapter and a 2 Liter pop bottle with the bottom cut off. I put a small amount of distilled water in the pop bottle.
I managed to get some bubbles out of the system. My question is what should the level of coolant be when the engine is cold? When I pop the cap off of the fill port, should I be able to see some coolant? This morning it’s dry as a bone.
Old 08-24-2022, 08:32 AM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Do yourself a favor and buy the ADM reservoir.
https://lsa-conversion-store.myshopi...sivoir-upgrade
Jaxcam02 is offline   Reply With Quote
Old 08-24-2022, 11:12 AM   #3
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
There should be coolant in the fill port. How long did you let the car run with the bleed bottle attached?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 08-24-2022, 11:38 AM   #4
hawk02
Coupe Newbie
hawk02's Avatar
I let the engine run until it was good and hot - maybe 15 -20 minutes. Then I let all the coolant that entered the bottle drain back into the system. It took about 4 hours for it to all go back in.
Old 08-24-2022, 12:02 PM   #5
MartinLe
MartinLe's Avatar
I used the OEM fill port that sits on the driver's side front corner of the SC. Remember, the fill port you are using MUST be higher than the SC or you will never get all the air out.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-24-2022, 12:41 PM   #6
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Wow that’s along time to bleed it. With the ADM reservoir it only takes a few minutes.
CW3SF is offline   Reply With Quote
Old 08-24-2022, 01:30 PM   #7
MartinLe
MartinLe's Avatar
I drank two beers watching the bubbles flutter to the top.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-24-2022, 03:09 PM   #8
Vigilante375
Drives: 2018 Camaro ZL1
You're better off installing a reservoir instead of messing with it like you are.
All I do is drive my car and check the fluid level in the reservoir I bought from LSA conversion's website every so often to make sure it's filled properly without having to run through the stuff you are doing and in question of.
Old 08-24-2022, 03:17 PM   #9
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Another vote for a reservoir
YouTube
Old 08-24-2022, 03:33 PM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
reservoir!
Old 08-24-2022, 04:06 PM   #11
MartinLe
MartinLe's Avatar
That does make it very simple. The reservoir sits above the SC. Eazy-peazy after that. Do you still have the OEM fill port? I don't recognize the black bar (LT4) going across the front of the SC. Hoses were in front of mine - are still in front of the 2650 - which the bleed port is still attached.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-24-2022, 04:37 PM   #12
AZIROC
Drives: '86 IROC-Z '18 ZL1
As others have said, just get the reservoir. Yeah.... I get it. It's pricey for what it is. But in the long run of never having to purge ur system (or more like it is always purging) that's worth the cost alone.
Old 08-24-2022, 04:44 PM   #13
Vigilante375
If you're asking what I think then no. You don't have to touch the OEM fill port ever again once you install an expansion tank. Just keep it filled appropriately.
Old 08-24-2022, 05:18 PM   #14
hawk02
Coupe Newbie
hawk02's Avatar
First off, I've had my ZL1 for almost six years and this is the first time I've attempted to purge air from the intercooler. And it wasn't because I was having a problem. I was just curious to see if there was any air in the system.
Secondly, I have my engine bay setup just the way I like it and no offense to ADM and everyone who has one installed, but I really don't want another ugly orange reservoir in the engine area. Plus, I never thought the location right above the exhaust manifold was ideal. Seems the best location would be towards the front grill where the coolant won't get heated from the exhaust manifolds.
Ok, with all that out of the way, I jumped the intercooler relay so the pump would run without the engine being on. This seems to be the best method to purge the air because you don't get the expansion of hot coolant. I did manage to get a few more bubbles out and there's now coolant showing when I pop the cap on the fill port.
So for $15 for the Dedicated Motorsports adapter, $.99 for the 2 liter bottle of pop, $4 for the fused bypass wire, and no cutting of any hoses, I'm satisfied what air was in the intercooler is now out.
