Old 08-23-2022, 07:17 AM   #1
Drnick
Drives: 22’ ZL1
Having a flat on your ZL1
Has anyone ever had a flat on there ZL1
While on the road? , and, if so, how did u
Fix it?, to get back on the road?
Drnick is offline   Reply With Quote
Old 08-23-2022, 07:29 AM   #2
ZLE dude
Drives: '18 ZL1 1LE
In a pinch I've plugged it (pulled the nail out) and used a buddies portable compressor to air it back up in a parking lot at work.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 08-23-2022, 07:44 AM   #3
HDRDTD
Had a blowout on a rear tire on my 5th gen ZL1 aways from home. Whatever caused the blowout left a hole large enough that the included fix-a-flat nor the cordless tire pump I had had a chance in hell of inflating the tire again.
I pressed the OnStar button, and they arranged to send a flat bed and had it towed to my local dealer.
Fairly simple.
Old 08-23-2022, 07:55 AM   #4
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Fairly simple.
Yikes flat beds scare me. lol. No issues getting it on as low as these cars sit?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 08-23-2022, 08:09 AM   #5
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I had a screw that I thought was a rock, scrubbed it off and then.. ruh roh, started loosing air fast. Pulled over at about 10psi, tried to air it up, but it was slow go. Tried the tire goo and just like first time I helped use it, it was total flop. Not sure how much I got in there, but proceeded to reair tire and get off the highway. Found tire shop, refilled tire and headed home - was less than mile out. Had local tire shop repair the puncture.
As fix, I now carry tire patch kit ( cords n glue ) instead of goo-in-a-can.
Scariest part -- having cars zoooom past you at 80mph! Don't take your eyes off that traffic - most folks are barely driving.
ing for grip.
http://www.motorsportsne.com/
Old 08-23-2022, 08:38 AM   #6
ATL_Ronin
Drives: 2022 ZL1
I'm not sure about the tire-goo included with ZL1s but I dealt with this with my Lexus RCF. After using the goo, I came to find out that the goo can mess up your TPMS sensor. Also, the goo did nothing for my situation and had to flatbed the car anyways. So to Vtor_ZL1's point, carry a patch kit and portable inflator, if that doesn't work call a tow truck.
ATL_Ronin is offline   Reply With Quote
Old 08-23-2022, 08:52 AM   #7
HDRDTD
No problem, at least in my case. I watched carefully as they winched it onto the flat bed to assure the front splitter didn't scrape..
Old 08-23-2022, 09:55 AM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I had a really bad experience with Cehvy roadside when it happened to me, locally the tow company was foul and those two couldn't communicate with each other well at all. I was on the side of the road for hours, then got it trucked over to the closest dealership.
It was at that time that I added roadside to my auto policy, they'll take it where ever I want/closest/etc which I think will work better for me.
I may opt for the compact spare though I could keep a plug kit in the trunk with the inflator.
Old 08-23-2022, 10:03 AM   #9
ATL_Ronin
Drives: 2022 ZL1
What compact spare would work on the ZL1? I'd definitely consider one as well.
Old 08-23-2022, 10:14 AM   #10
WhiteMale
I meant to say Modern Spare, thats the brand name
https://modernspare.com/product/2016...e-kit-options/
Old 08-23-2022, 02:13 PM   #11
Drnick
Drives: 22’ ZL1
And where would u put the spare tire and kit?
Would it actually fit in the “Trunk “?
Old 08-23-2022, 02:34 PM   #12
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I bought a full kit when I had my ZL1. It easily fits in the trunk.
Old 08-23-2022, 02:36 PM   #13
WhiteMale
A fullsize 305/30/20 fits in the trunk with ease so this is not a problem.
Old 08-23-2022, 03:23 PM   #14
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
You have to use fix a flat that is tpms safe
