08-21-2022, 12:21 AM | #1 |
Drives: 2018 2SS M6 Hot Wheels Camaro Join Date: Mar 2017
Question about front shroud where hood lever is in engine compartment
Question: On the black painted metal shroud that surrounds the hood locking mechanism, and is right at the front of the engine compartment, do the four bolts that are there serve multiple functions? There are four bolts, and two bump stops. The two front most bolts are partially up on my car, and the back two are tightened all the way down. The front two, that are up a bit, do not budge if you try to hand turn them. They’re not loose. I thought they were cross threaded, when I noticed earlier today, then I searched images of hood compartment for other 6th gens on Google, and saw that some are down flush, and others are like mine, slightly up. It’s always the front two that are up a bit, if any are up. I’m starting to think, maybe they are adjustment screws for something as well. Any ideas or info on this? Thank you! Photo attached has two screws, that are slightly up and not flush, circled in blue.
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars: 2017 1SS Nightfall Gray Metallic w/A8 and NPP 1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps. |
08-21-2022, 02:29 AM | #2 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
See these links for more info: https://www.camaro6.com/forums/showthread.php?t=555225 https://www.camaro6.com/forums/showp...7&postcount=21 |
08-21-2022, 10:01 AM | #3 | |
Awesome! Thank you for the information! I tried searching the forum, but I must have not hit the right key words. Super helpful, and much appreciated. I thought they must adjust something, but wasn’t sure it would be the front fascia. Have a great Sunday, and thanks again!
