Old 08-18-2022, 06:45 PM   #1
sckt
Drives: 2019 ZL1
Brake Job Pricing
Got a couple of prices for a brake job from the mechanic I have used for years and trust
4-wheel pads and rotors
2019 ZL1
aftermarket parts $900
OE parts $3,000
What am I missing here? The mechanic said it's the most expensive brakes he has ever quoted.
Thanks for any input
sckt is offline   Reply With Quote
Old 08-18-2022, 07:04 PM   #2
NG329
Drives: Chevrolet Camaro ZL1 1LE
Rockauto.com
NG329 is offline   Reply With Quote
Old 08-18-2022, 07:13 PM   #3
SoCal Smith
SoCal Smith's Avatar
Drives: 2019 Camaro ZL1 1LE A10
What's the quote breakdown? What aftermarket parts?
SoCal Smith is offline   Reply With Quote
Old 08-18-2022, 07:26 PM   #4
Vigilante375
Drives: 2018 Camaro ZL1
Why are you replacing the rotors? Are they damaged?
Old 08-18-2022, 07:41 PM   #5
red6.2
Drives: 2010 camaro
Sounds about right for a full replacement. If he's a credible mecahnic, pay him for the job. or you can can get a sloppy mechanic to do it fro a 100 or 200 bucks cheaper and mess up with cosmetics on the car... who knows. If you trust him, do it!
red6.2 is offline   Reply With Quote
Old 08-18-2022, 08:34 PM   #6
MatthewAMEL
MatthewAMEL's Avatar
Rock auto has OEM rotors (F/R) and OEM pads (F/R) for $1,400 total.
Either your mechanic doesn't know where to shop for parts or he was hoping to get a few bucks from you.
gmpartsdirect.com is also a good place for OEM hardware.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 08-19-2022, 12:24 AM   #7
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Super easy to replace yourself, that price is a shock to me as I've done an entire refresh on a custom Wilwood, 14 inch 2 piece rotor, 6 piston calipers (front), and 13 inch 2 piece rotor, 4 piston (rear) + pads and new wilwood fluid for slightly less if not the same.
Damn Brembo shit is expensive!!!!
Mac7504 is offline   Reply With Quote
Old 08-19-2022, 06:57 AM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
$3000 sounds about right if he's going to a stealership parts dept.
Old 08-19-2022, 08:01 AM   #9
sckt
Drives: 2019 ZL1
Fronts have a pretty good groove. Not thinking they can be turned.
The rears are probably ok to reuse. Those are the cheap ones though.
Old 08-19-2022, 08:03 AM   #10
sckt
Drives: 2019 ZL1
Originally Posted by NG329 View Post
Rockauto.com
Looks like $406 for OE rotors there
The mechanic said ~$600 each for the front and they listed for $800
Going to get a price from a dealer too.
May just end up doing them myself.
Old 08-19-2022, 08:13 AM   #11
sckt
Drives: 2019 ZL1
Stealer finally called me back
My Mechanic was not joking.
List on the rotors $828 each
Stealership quoted $2,510 for just the fronts
Old 08-19-2022, 08:19 AM   #12
NG329
I literally just got my entire brakes done front and rear for well under $2Gs. You need to make friends with a local shop man.
I have a local shop that I use frequently and I always tip the mechanics, buy beer, breakfast etc. When I need work done on the fly they get me sorted quickly and don't beat me over the head.
Stay away from dealers unless you're doing warranty work. For consumables, any decent shop can get you sorted.
Old 08-19-2022, 08:21 AM   #13
NG329
I mean, stealership is a bit harsh -- unless you're talking about markups on new and used cars then it fully applies. I think that it's just the cost of doing business. It's expensive to run a larger facility, keep the lights on, pay staff and mechanics, etc... so they are less likely to be in a position where they can give discounts etc.
Get a local mom and pop shop around the way to change your brakes. Unless you're bleeding them, I've seen homeless guys get the job done to make a quick buck. Literally.
Old 08-19-2022, 09:02 AM   #14
sckt
Drives: 2019 ZL1
read the first post. I got the $3k quote from the mom and pop I've used for years. Still seemed high.
I rarely use a dealer for anything other than warranty work.
Don't want to beat up on him, but if I can get all the OE parts for around $1,400 from Rock. It is probably worth my time to do it myself.
