![]() Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Corsa vs. Borla OR a better mod?
Stock 2SS with NPP. Question: Which exhaust to choose? Corsa for the iconic muscle car sound or Borla for a deeper tone? Do I need the 'Y' pipe add on? Seems like a lot of $$$ to put down on this mod for little HP gain and I am not even sure a huge noticeable difference in tone? I normally run in Sport mode.
Is/are there a better mod(s) out there for about the same $$$. Looking for a good bang for the buck. Any suggestions welcome! I am already running Cold Air Inductions CAI as well as a Soler Performance Throttle body and Controller. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I had a Borla on my C6 Corvette and loved the deep tone. It also had Kooks long tube headers and cats along with a tune.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Im also interested in seeing which is the more popular option.
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
I went with Corsa's NPP for the classic muscle car rumble. Love it, not too loud, but not quiet at all. With the NPP you can put it to Touring and still get the muscle car rumble, toned down a bit.
There is a very noticeable difference in sound between sport/track and touring/snow/ice/stealth with Corsa's NPP.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#5 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
#6 | |
Bang for the buck would be buying a set of TSP catless headers, resonated X piped, tied into your factory NPP muffler. Would require a tune, but even after the headers, install, and tune you be about the same cost as a Borla or Corsa NPP axleback. And the headers will give you a bump in sound and 25-30whp more power. Then you can sell your throttle controller and put that money into a flex fuel sensor that will allow you to run pump gas, E85 or a blend of both... There is another 20-25whp gain.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
If you're on a budget a catback or axleback at these prices is not a good choice on these cars that see no gains from new mufflers(sub-900 hp).
J-Rod Built and Matt@FSP Tuned |
#8 | ||
#9 |
"Bang for the buck would be buying a set of TSP catless headers, resonated X piped, tied into your factory NPP muffler." Any suggestions where to buy? I searched TPS Catless headers and it shows a different brand headers? I honestly know nothing about headers... 1 7/8 vs 2"? Assume you can buy the X/Y pipe from Corsa or Borla? All suggestions and comments welcome!
#10 | |
https://www.texas-speed.com/c-3288-h...maro-2020.aspx
#11 |
This is all good info.. ..I was thinking of adding mufflers but its sounding like its just not worth the money.
If I were to do headers and delete the secondary cats, would I need to do anything to the stock X-Pipe / intermediate pipe? Would sound increase on my Stock NPP at all? Its sounding like the best bang for the buck for boltons are CAI Headers !Secondary Cats Flex Fuel Kit Tune for E-85 .. Then when deciding to go up in power .. MSD Airforce Intake Cam Heads (or port stock heads) Sounds as though the rest of the stock exhaust will still handle this without issue? Also which Flex Fuel Kit should I get? |
#12 |
I can't answer how you want to join the headers to the stock cutback, but yes, it is going to be MUCH louder in certain situations.
Cold starts will be real loud, and when you go WOT it will be also. Your car will turn in to an animal with those mods, and it will sound like it too. The stock NPP is also the quietest muffler you will find, so it's good to leave that on when you go headers and then decide if you want to go louder. Chances are, it will be plenty loud enough for you.
#13 | |
#14 | |
It should say when you order it if it connects to factory or not. They're in Texas, give them a call.
