Old 08-14-2022, 12:41 PM   #1
Jrwimmer
Drives: 2022 Camaro ZL1
Drag Tire Help
I have some 17x10.5 Drag Star Wheels
Thinking about 315/35/17 MT Street R or 305/45/17 MT Street R
Will this fit on a stock ZL1 without rubbing etc? Should I have gotten 17x9.5?
Also would this be the best tire for strictly dragging? I will never drive in the rain etc so that doesn't matter at all
Thanks so much!
Jrwimmer is offline   Reply With Quote
Old 08-14-2022, 01:28 PM   #2
laynlo15
Drives: 2022 Lt1 A10
I ran a 305-45-17 on a 10.5. I should fit ok, 315 is too wide for a 9.5 wheel.
Old 08-14-2022, 03:36 PM   #3
Jrwimmer
How did you run with the 305? Would the 315 make a big difference if they fit?
Old 08-14-2022, 04:20 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Thanks so much!
You definitely want the 305/45/17 ET Street R. A 35 tire doesn’t have enough sidewall and would probably be too small of a tire overall too.
Old 08-15-2022, 08:20 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I have 10.5" Racestars with 305 SSs. The 305s fit fine. I did perform the relocation on the driver's side wire harness, which likely helps, but get no tire rub anywhere. There is no part of my tires touching anything but the wheels though. I did nothing else to fit them except the harness relocation. The Rs are probably the better tire, and I say "probably" because I don't have experience with them, but am completely positive everyone else who HAS commented on the is 100% correct. I can, however, tell you that the SSs are okay on the street. You can't go WOT from a dig on them, though, and if you spin them enough, they'll "ball-up" (I don't know if there's a term for this condition, but that's what I think I've seen a couple people use), and you won't get much better traction than stock tires until you "clean" them off. Then they'll get back to hooking about as good as before. I'll be trying Rs next time though, or maybe Nittos.
However (even though ask, I'll add comments, just in case) - I've read there should be a minimum of something like 0.100" clearance between any part of the suspension/brakes to the inner barrel of the rim. There is not this amount of clearance between the caliper and barrel. While the barrel hasn't contacted the caliper yet, it has rubbed on the caliper label, so it might as well be making contact in my book. JMO.
'20 ZL1 Black "Fury"
Old 08-15-2022, 08:25 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Thanks so much!
Mickey's R tire vibrated like crazy on my car, so I went to the Toyo rears. Might try ET Street S/S someday
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-15-2022, 10:12 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
My SSs don't vibrate, but they sure like swaying. You car's making A LOT more power than me, so these aren't going to stick as good as the Rs. I'm sure you already know that though.
Old 08-15-2022, 10:36 AM   #8
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
I run 305/45s ETs on my welds and they work great!
ChadSZL1 is offline   Reply With Quote
Old 08-16-2022, 11:54 AM   #9
Jrwimmer
Is there anyway to prevent that rub? If i get a 17x10 and run the same tire would it eliminate this problem>?
