TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 08-10-2022, 08:48 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Hello...Anyone here?
What the hell is happening peeps?
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
edog is offline   Reply With Quote
Old 08-11-2022, 12:34 PM   #2
BAD DAB
BAD DAB's Avatar
Hey edog..............what's up? I brought your name up just the other day. I was telling some of my friends at work about the epic Camarovan from Dayton to Indy for Camaro5fest III. What a memory.
Old 08-11-2022, 06:09 PM   #3
The SS Godfather
The SS Godfather's Avatar
Drives: 2010 CAMARO RS/SS
Hello edog, i don't know you "BUT I LIKE THE CUT OF YOUR JIB" !!
The SS Godfather is offline   Reply With Quote
Old 08-14-2022, 10:26 PM   #4
edog
edog's Avatar
BAD DAB, that was epic!! 😆 never to be done again. How have you been? I'm going to come down to Richmond and hook up with you guys soon.
Old 08-14-2022, 10:27 PM   #5
edog
edog's Avatar
Hey!
Old 08-14-2022, 11:05 PM   #6
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
yep were still here
2010 rs Camaro with GFX
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 08-15-2022, 01:32 PM   #7
BAD DAB
BAD DAB's Avatar
Old 08-18-2022, 03:31 AM   #8
edog
edog's Avatar
HMMM, I wonder where everyone went. Are they all on the 6th Gen side?
