Old 08-09-2022, 08:35 AM   #1
WillyZ83
WillyZ83's Avatar
Drives: 18 zl1 garnet red
1/4 track tire, 17" wheel ?
Picking up a set of dedicated 1/4 mile track wheels for the 22 zl1. Car is stock, for now... Went with forgestar f14 17x10
Looking for tire options, what have you guys run and suggestions? thanks
IG - @zl1_will
2022 zl1 740hp / 730tq stolen
2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms
WillyZ83 is offline   Reply With Quote
Old 08-09-2022, 09:04 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
305/45/17 ET Street R is pretty much the go to for that wheel size at the track.
Old 08-09-2022, 09:15 AM   #3
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
ChadSZL1 is offline   Reply With Quote
Old 08-09-2022, 09:25 AM   #4
WillyZ83
WillyZ83's Avatar
Thank you sir, I found a deal on that tire as well.
IG - @zl1_will
Old 08-09-2022, 11:28 AM   #5
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
I switched from the M/T's to these, https://www.summitracing.com/parts/hoo-18825dbr
way lighter and they hook pretty darn good! Not DOT though... I do drive them on a dry street!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 08-09-2022, 11:41 AM   #6
WillyZ83
WillyZ83's Avatar
Those white letter Hoosiers look gangster too. May be the next set to try out
IG - @zl1_will
Old 08-09-2022, 03:27 PM   #7
2018ZL1
2018ZL1's Avatar
I normally put the white letters on the inside! lol I am old and dont want to draw any attention!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 08-09-2022, 03:30 PM   #8
clg82
Drives: 2020 Camaro ZL1
Looking at doing this myself, thanks for the suggestions. OP where did you buy your wheels from?
Old 08-09-2022, 04:12 PM   #9
KingLT1
KingLT1's Avatar
That is for sure a better hooking tire then the ET street R. Just not street legal. But if track only then yeah this all day.
Old 08-09-2022, 04:39 PM   #10
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
FYI that tire will not technically be legal to run under the new NHRA Street Legal rules (allowing you to run 9.0/150 without a cage). Supposed to be DOT tires only. If your track doesn’t care, then feel free to circular-file this message.
Old 08-09-2022, 04:39 PM   #11
laynlo15
Drives: 2022 Lt1 A10
I ran both tires on my 16 SS, NA on the Hoosiers and also with the Magnuson 2300. They were both close but the MT was quicker in the 60 ft but the Hoosier was more mph thru the traps. More mph just because the Slick will get taller down track where the radial stays flat. Radial is more stable with a cross wind. Believe I've run both of these multiple times with different combinations. I'd run the run R myself unless you're going to do a drag pack and trailer to the track. Just my opinion. There is 100 lbs difference if you do a complete drag pack with slicks and a bias skinny up front. Drag pack with radials will save about 45 lbs.
Old 08-09-2022, 07:08 PM   #12
clg82
What PSI were you running on the rears at the track and did you go skinny’s up front or did you leave the stocks? And aside from weight what is the benefit of running stocks up front as opposed to skinny’s?
Old 08-10-2022, 05:46 AM   #13
laynlo15
If you're going to run a slick on the rear, you need to run a skinny up front and not a radial tire. If you run a drag radial you can run about 18 to 22 lbs at the track. Its been a while since I ran a slick on the rear but I think I ran about 14 to 16 lbs with the Hoosiers, you'll either need to screw them down or use Permatex High Tack Cement on the beads to keep them from spinning on the wheels. I use the Cement on the drag radials also.
Old 08-10-2022, 06:32 AM   #14
Joshinator99
Moderator
Or use beadlocks…
