Dashcam/radar fuse
What kind of fuse does a 6 Gen Camaro SS have? Mini Fuse, Low Profile Mini Fuse or ATO Fuse? Which is the best option for dash cam and radar detector hard wire? I will probably wire from fuse box under the hood.
Micro2 / ATR, see circled below. Wish I understood why so many standards were/are necessary.
Thank you, I thought the answer was more complicated.
Oh, as to the second part of your question that I forgot to reply to (sorry), I wired the radar detector to the overhead console using Gen5DIY's split harness, and the dual dashcam to the trunk fuse box, with a parking mode switch.
There is a clear path above/behind the headliner, above the door and all the way down the pass side C pillar (behind the trim panel) for the rear cam and the power cord, with a convenient opening into and under the battery space. I wrapped the cable in an OEM sheath, so it doesn't look ghetto or too out of place in the trunk. The entire setup looks 99% OEM, even the headliner has a notch in front center that I guided the few inches of visible wiring through. I don't want to go through the firewall and even less a door for anything, if at all possible.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-07-2022 at 05:51 PM. |
![]() Drives: 2018 Camaro 1SS Join Date: Mar 2018
I tapped into the 12v outlet in the center console (purple wire) for the radar detector because I wanted to install a mute button for it in that area as well. Ran the wiring from there behind the passenger footwell, up the B pillar and along the headliner to the left side of the rear view mirror. I don’t have a dash cam yet, but plan on doing as arpad_m and tying it into the trunk fuse box.
2018 Nightfall Gray Metallic 1SS
| Mishimoto Catch Can | Roto-Fab Oiled Intake w/ Sound Tube Delete | GM Dark Tail Lights & 3rd Brake Light | JWM LED Sidemarkers | 35/5 Ceramic Tint | AWE Track Exhaust w/ Resonators & Link Pipes | |
