Old 08-03-2022, 04:31 PM   #1
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Trade
My 21 rs v6 manual 35k miles and $10k for 21 v61le 8k miles.
Gen6cyl is offline   Reply With Quote
Old 08-03-2022, 05:26 PM   #2
BAUSS 1LE
BAUSS 1LE's Avatar
Drives: 19 SS 1LE
Ok?
2019 SS 1LE Riverside Blue
BTR 225 cam, West Coast Cylinder Ported Heads, Kooks LTH with high flow cats, Lethal Garage flex fuel, LT2 ported IM, 95mm TB, Rotofab intake, AWE track, Mighty Mouse catch can, Eibach lowering springs.
Built by Red Barn Racing
BAUSS 1LE is offline   Reply With Quote
Old 08-03-2022, 05:47 PM   #3
Gen6cyl
Just asking for opinions on this deal.I got it down from $12,300 difference.I don't want a V8. Asking if miles diff. and 1le package is worth it in y'alls opinion and if 1le pkg will be valued years down the road.
Old 08-03-2022, 06:05 PM   #4
BAUSS 1LE
BAUSS 1LE's Avatar
Drives: 19 SS 1LE
Definitely... If you are going to be tracking it, if not there really would be no reason.
Old 08-03-2022, 06:06 PM   #5
armycop71
Love my Satin Steel LT-1!
armycop71's Avatar
Drives: 6-Speed LT-1...
Cars depreciate, so it's not a wise investment. You seem to drive a lot of miles if you put 35K on a 2021. You may want to look at your primary use, and decide if harsher ride and higher maintenance cost for tires, etc is worth it. Unless you track your car often, you should probably keep what you got.
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels
Technology Pkg|NPP|Satin Blk Pkg
ZL1 Rock Guards|Red Knee Pad Set
EOS Track Spoiler|EOS 1LE Splitter
PBC LT1 engine built by Debi Lewis
armycop71 is offline   Reply With Quote
Old 08-03-2022, 06:17 PM   #6
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Nope, not a good deal in my eyes. Not to mention the trade excess tax bill, more than likely higher interest rate on the loan
Old 08-03-2022, 07:27 PM   #7
LT1ornothing
Drives: 2020 LT1 M6
I would only do it if you track on the road courses or autocross. Otherwise, not worth it at all. You already have a limited slip in yours because of the 6 speed manual, same engine and same transmission as the 1LE. You are only missing suspension, brakes and tires. And you can buy better tires for your v6 than the 1LE.
I know very well your reluctance to the V8, but only a v8 upgrade is worth your trade plus $10K in my opinion. Good luck.
Old 08-03-2022, 07:29 PM   #8
Gen6cyl
I commute 400 miles a week on rural roads. Y'all are right I got the right car 1.5 years ago. I love a responsive chassis. When I read stiffer suspension and chassis bracing on the 1le I start drooling. I don't need the spoilers just more damage when I hit animals or go on a dirt road. And the coolers more potential Ieaks. I'llput on my B6 dampers I got last week. Thanks for the help.
Old 08-03-2022, 07:40 PM   #9
Number 3
Hail to the King baby!
Number 3's Avatar
Run them both through KBB and see if there is a 10k difference. Seems high to me though.
Old 08-03-2022, 07:47 PM   #10
Gen6cyl
I talked to a dealer about a 2020 lt1 33k miles not long ago, they wanted $13,900 diff.I don't need 1le brakes either.I found a chart on this fourm a bout chassis bracing on gen 6.The v6 1 Le has same bracing as SS. At 28 k miles I got general g max summers, they are in their sweet spot now. I got the rear a little loose today just by turning hard. A big diff from run flats.
Old 08-03-2022, 08:19 PM   #11
Gen6cyl
The v61le option is $4500 and I have 27k more miles and the dealer had to be fed. I've made a few offers over the last6 months , this is the best deal .Is the car situation changing ?
Old 08-03-2022, 08:34 PM   #12
Chutzpah
Chutzpah's Avatar
I like that,” the dealer has to be fed”. How true… but they’d be eating real good on the $10K deal. Making $ off the LE sale itself, making money off your car, making money off the refinance (if you go through someone they deal with, making money off dealer fees.
As far as you, theres a couple bucks invested in new tires, so a bit of a loss. All of the other sale / finance and tax costs would bring you closer to $13k or $14K, all said and done. This is why buying once, crying once is best. Although, I can say for certain that I’ve knowingly broken this rule numerous times. I’m working on my habit…. Cars are a killer
Good luck
Old 08-03-2022, 09:33 PM   #13
Gen6cyl
Good luck
And I spent $490 on B6 dampers last week
Old 08-04-2022, 04:21 AM   #14
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
You're better off staying with what you have
nancygrl is offline   Reply With Quote
