Old 08-02-2022, 02:59 PM   #1
Jeauxy
Jeauxy's Avatar
Drives: 19' SW ZLE
What size MightyMouse Wild Catch Can?
What's going on Everyone -
Hopefully this isn't a stupid question, but I am about to purchase the MM CC and was wondering if someone could help me understand which size of the wild CC that I need.
I see the 8, 10, 12AN with the hp next to it. Do yall just get the largest one just to be safer than sorry if you mod down the road? Or is the 8AN good enough for my basic bolt ons ZLE?
I am unfamiliar with the AN fittings and when one should upgrade to the 12AN.
The interchiller I am going to get has the option to "upgrade" to 12AN fittings as well.
Any info on if I need to upgrade to 12AN on these parts and why would be awesome. Thanks in advance!
Jeauxy is offline   Reply With Quote
Old 08-02-2022, 03:05 PM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Get the 10an, it’s way more then enough.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-02-2022, 03:29 PM   #3
Jeauxy
Jeauxy's Avatar
Drives: 19' SW ZLE
Saw your other thread and you actually heavily convinced me to get the MM. So thank you for that and your response on the 10AN.
Should I stick to the 10AN FI interchiller as well or upgrade to the 12AN hose and fittings? Not sure the reasons to step up to 12AN for our cars.
Old 08-02-2022, 05:01 PM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I can’t quite recall , but the lines on aftermarket blowers are 3/4”. ID which are an12. I thought the FI comes with those standard (purchased separately).
I would just use all AN12 because if you ever upgrade the blower you’ll need it.
Old 08-02-2022, 06:43 PM   #5
Jeauxy
Jeauxy's Avatar
Drives: 19' SW ZLE
Ahh ok. I was ordering the interchiller off of CSP and the 12AN fittings are an extra +$70.
Old 08-02-2022, 07:30 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You need the fittings regardless. You either buy them Yourself or through them.
Old 08-02-2022, 08:22 PM   #7
Cleancoupe
Drives: 18 ZL1 1LE
They don’t recommend their wild cans if you will be taking your car on a road course just an FYI
Cleancoupe is offline   Reply With Quote
Old 08-03-2022, 11:00 AM   #8
Jeauxy
Jeauxy's Avatar
Drives: 19' SW ZLE
Got it. Thank you for the clarification!
