Old 08-01-2022, 11:06 PM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Low side pressure drop - with less e content
I just logged a run with e41.2 and my low side pressure disappeared. Here are some numbers:
e50.1
6600 rpm
low 74psi
high 2873psi
IPW 4.9
e41.2
6600
47
2046
5.6
The e50 run topped out at 7K rpm, 70/2488 and 5.02 ipw with 14psi of boost. I had 15.3 @ 6700.
The e40 run started tanking at 6K rpm: 66/3016, 4.85 ipw. The low side kept dropping from there with their respective numbers dropping/rising respectively. If anyone would like to see the logs, let me know. I tried to attached them but I got the invalid attachment notice.
Any thoughts would be greatly appreciated.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 08-02-2022, 12:49 AM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
e50.1
6600 rpm
low 74psi
high 2873psi
IPW 4.9
e41.2
6600
47
2046
5.6
What’s on your low side?
I’ll send you a pm.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-02-2022, 01:09 AM   #3
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
e50.1
6600 rpm
low 74psi
high 2873psi
IPW 4.9
e41.2
6600
47
2046
5.6
Was is colder the day you logged E40, compare to the day you run E50? Did you log in the same gear, or put more load on it this time?
Another factor is COT. Did you log that channel to see if cat overtemp protection kicked in, and put too much strain on your fuel system?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 08-02-2022, 11:03 AM   #4
MartinLe
MartinLe's Avatar
Both pulls were in 90 degree weather and very close to identical in setup and execution. I have some fellas smarter than me looking at the logs. I should have this sorted out shortly. Stay tuned.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-02-2022, 11:14 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I doubt it's anything to do with lower E as that would be backwards far as fuel demand. What do you have for a low side fuel system?
Old 08-02-2022, 12:49 PM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Good call on the COT. That can have a huge impact.
Old 08-02-2022, 01:45 PM   #7
KingLT1
KingLT1's Avatar
So can variable voltage system. That is why generally JRE recommends the voltage booster to keep low side voltage the same. But yes COT can cause that issue, so can positive long term fuel trims.
Old 08-02-2022, 01:50 PM   #8
MartinLe
MartinLe's Avatar
JMS. Otherwise stock. The bizarre fact is this happened after the final tune when I installed the 125 flex fuel package. I replaced the low side pump and immediately lost a couple cylinders. My local tuner looked at it and thought I got some debris in the fuel system with the pump r&r that clogged the injectors. I wanted to do the blower/cam thing anyway, so instead of messing with the current build, I bought the +30s and moved forward. I sent the injectors to FIC and they said they were fine. They could not tell if they were clogged, but when the ran them through the test, they performed without issue.
Fast forward to now, the three pulls (e50) needed for the tune went without issue. The first pull at e40 - deja vu all over again.
Why would the COT kick in suddenly at very similar, (more that 90 and less that 100 degrees), atmospheric conditions?
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-02-2022, 02:00 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
COT is off. His pressure is dropping into the 40’s like the JMS isn’t even volting properly, or working at all or there is indeed a problem with his low side.
The behavior though from the logs looks pretty identical to mine if I was to disable my aux pump. I’m Having him try a few pulls in a higher gear, monitor the voltage from the JMS and see how the pressure is on 93 with the JMS disconnected.
Should be able to tell if it’s the JMS or the pump itself. If he had an aux, I would also Suspect a restriction in the filter from Drilling the tank. (Not the case here)
Old 08-02-2022, 05:05 PM   #10
KingLT1
KingLT1's Avatar
Sounds like a JMS issue. If the pump was bad I don't think it would hold 47psi. That sounds like what the pressure would be with standard 12volts and no booster.
Old 08-02-2022, 06:29 PM   #11
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Exactly this. He’s probably making similar power to me and when I had issues with my aux pump my low side dropped into the 40’s.
Just seems like the JMS isn’t giving the voltage.
Old 08-02-2022, 06:52 PM   #12
MartinLe
MartinLe's Avatar
I am going to add those channels for the electrical signals to the fuel pump and make a couple pulls as you suggested. I have a little less than 1/3 a tank of gas. Afterwards, I will fill up the tank with 92 which should pretty much drown any appreciable e content and do another pull. We should know after that, wouldn't you say?
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 08-02-2022, 07:28 PM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yep, If it stays holding consistently on pump then I’m
Going to assume there’s an issue with the JMS.
Old 08-02-2022, 09:30 PM   #14
Crusher Camaro
Drives: 19 ZL1
should be able to check the JMS fairly easy.
key on / engine off
check voltage on the JMS white wire, then have somebody cycle the throttle and watch the voltage. should start to increase at the 50% throttle mark if setup like Teds instructions.
I was having issue with my JMS right after install. found the T-harness at the pedal had a bad connect to the signal wire. took the harness apart and replaced the connector, new heat shrink and all is normal now.
Crusher Camaro is offline   Reply With Quote
