Old 08-01-2022, 04:58 PM   #1
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Turbo vs Supercharged, Which Would You Pick and Why
I know, ancient question but still interesting to hear perspectives. How many turbo cars have you owned and will you go back?
In terms of power potential, there isn't much of an argument. BMW is squeezing 520 rwhp (dyno, not claimed) out of a 3.0 L motor. Most ZL1s don't put down much more (560 on average) with DOUBLE the displacement (granted 24 psi vs 9 psi). McLaren gets 750 rwhp out of a 4.0 L. Quite a few Audi guys get 600+ out of their 2.5L (modded)
Turbo lag isn't the argument it once was, lag is there at lower rpm, but not terrible. Supercharger generates a very linear power curve but also a little boring? Better gas mileage when you're cruising is another advantage.
Please no EV stuff, we know a Plaid will do x in a roll on
ZX-10R is offline   Reply With Quote
Old 08-01-2022, 05:17 PM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
My new 22 bmw x4m comp with mid pipe and racechip just put down 587whp and 563tq. There’s still a little turbo lag at low rpm’s.
I like both tbh.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-01-2022, 05:18 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would rather have more displacement with a positive displacement supercharger using less boost vs a tiny motor on moon boost. It's more reliable and a better power curve.
What many fail to realize is that GM's ancient technology is cheaper and easier to work on. So while all these smaller displacement high boost engines look great on paper, 99% of the owners barely know how to change the oil in them.
Old 08-01-2022, 06:18 PM   #4
ZX-10R
ZX-10R's Avatar
Good point - and reliability is still a great argument for the higher displacement, lower boost formula (in general). With that said, many owners seem to get acceptable service life out of high boost mouse motors (how well they hold compression after say 70k miles is less well documented)
Another good point, but most owners don't do much of their own work aside from oil changes
They have M3/4 xdrive comps running 9s now
Old 08-01-2022, 06:29 PM   #5
turbo_jimbo
Drives: 2022 ZL1 1LE
I prefer turbo setups, but both have merit. I'm sure the daily use MPG would be much better with turbo than sc on the zl1, but who cares? Power is power. For most applications, turbo's are easier to install and cheaper to come by. I'm finishing up a turbo build on my other car, once I finish getting the computer stuff sorted, should be good for around 600whp, but that's a 2.4l 4 cylinder in a car that weighs around 2000lbs.
turbo_jimbo is offline   Reply With Quote
Old 08-01-2022, 06:34 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I have an x4m though. But even the x4m,s are low 10’s on a bm3 tune and down pipes with e30 and low 7’s 60-130. My DME is locked though, it needs to be sent overseas so for now racechip it is.
Crazy that an suv is in the 10’s. I still need to put the dragy in it and see what mine can do with/without racechip. I didn’t get a chance to do it before the dp and mp.
Old 08-01-2022, 06:40 PM   #7
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
I have owned several turbo engine cars and but I now have a C6 Grand Sport that has a positive displacement supercharger.
With most turbo cars which use a single turbo, the turbo is sized for a certain RPM range. So either they have a small turbo that spools quickly with no or little lag but then fall on their face in the upper RPM range. Or they have a larger turbo that doesn't start to build power until 3K or more RPM's but pull to redline. Now cars that are twin turboed with both a small and a larger turbo will have power everywhere but those are much less common nowadays.
The thing I like with my PD supercharged C6 is that it has power everywhere and behaves just like a naturally aspirated car. Instant torque no matter what RPM. And there is little parasitic loss as it has a bi-pass valve when not in boost (most modern supercharged engines have this).
And then there are the centrifugal superchargers like ProCharger that are basically a belt driven turbo. Not as much boost off idle but boost continues to build higher and higher as RPM increases.
So I like both turbos and superchargers but favor superchargers.
Spaceme1117 is offline   Reply With Quote
Old 08-01-2022, 06:44 PM   #8
ZX-10R
ZX-10R's Avatar
Ecotec? What car?
Old 08-01-2022, 07:25 PM   #9
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I have had the opportunity to drive both FI applications long term and my rationale lies behind a lot of what you guys are saying. I agree entirely!
I love the way PD cars behave. They are better mannered and if you have never driven a supercharged one, you would hardly know that a vehicle has one besides the noise they generate with how much like an NA vehicle they drive.
758 HP/ 804 TQ
Old 08-01-2022, 07:51 PM   #10
Z OH 6
Drives: 2024 CT5-V Blackwing
For ultimate power and flexibility, turbos win.
Old 08-01-2022, 08:19 PM   #11
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Merit to both set ups but for street driving, and at the track, I think a larger displacement engine with a SC has a more linear, less peaky torque and HP curve which translates into having a more immediate, smoother power delivery. Also, just me, but I think heat is somewhat easier to control in a SC set up.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 08-02-2022, 12:10 AM   #12
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
For me, on the street, I just very much dislike how the power hits with a turbo car.. To me, it's like nothing nothing nothing, then boom, power! I simple can't get used to it and do not enjoy it very much. That said, I do like how much easier it seems to add power to turbo setups and I enjoy the sound of turbo flutter but this alone is not enough for me to purchase one.
I even tracked a 2020 488 GTB a few times and if I was in the wrong gear, even slightly, the engine very much struggled to keep up. I addressed this with my instructor because he seemed to keep telling me to shift early but fell on deaf ears..
Just my take.
Mac7504 is offline   Reply With Quote
Old 08-02-2022, 06:29 AM   #13
Spaceme1117
Probably the best turbo engine car I have ever owned/driven is the LNF powered Saturn Sky Redline. Used a 2.0 liter direct injection with a twin scroll turbo. No turbo lag at all and had a very linear power delivery all the way to redline.
Old 08-02-2022, 07:43 AM   #14
...and you have just described a positive displacement supercharger
