ZL1 clutch question
2022 ZL1 clutch; is this a twin disc clutch?
Thank you Al Oppenheiser!
yes
![]() Drives: 19 ZL1 Join Date: Jan 2019
most certainly a twin disc.
Ok, so ZL1 has twin disc clutch, is engagement different then
Typical single disc? ie more or less like a “light switch” |
Dyno Show Queen LOL
I would weight the asm and get something lighter or same weight in twin or triple.
I'm having an issue of inertia still moving and causing 5th and 6 gear problems at 150 plus. every other speed and shifting is butter. Originally I though I was hanging up so not to put in reverse from 4th to 5th. But I have gotten 5th stretched out and 6 gear was hard to go into as well. If I granny shift no problems basically what to blead off a rpm/speed. This is what trimec recommended is going on.
I’m talking about initial engagement from stop
Shifting through gears is like butter, but from stop Compared to my previous camaro and corvette It sucks! |
#7 | |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
If I were a betting man, I would think that maybe you are heat soaking your clutch line, and by the time you hit those speeds, there is enough heat in the clutch fluid to make it not disengage as far, which would cause issues. |
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
#9 |
Dyno Show Queen LOL
What can I do other than the motul I'm using?
