Old 07-28-2022, 07:57 PM   #1
fastliferider
fastliferider's Avatar
Drives: 2016 SS 2SS
Octane
I'm sure this has been addressed but I'm new here. Does anyone other than me run only 93 octane? How does the 'mid grade' of 89 octane run in a 6.2L?
fastliferider is offline   Reply With Quote
Old 07-28-2022, 08:06 PM   #2
Devstrike
Devstrike's Avatar
Drives: 2020 Camaro LT1
I run premium only if it's available I get 93 but if I can't I put 91 in since its still premium. As for running 89 (Midgrade) it is something I do not want to experiment with in my own car.
Devstrike is offline   Reply With Quote
Old 07-28-2022, 08:12 PM   #3
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
If you can get 93 use it. I use 93 in my v6. If you want to save money use 5w-30 synthetic motor oil.
Gen6cyl is offline   Reply With Quote
Old 07-28-2022, 08:21 PM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Use 93 Octane if it’s available in your area or 92. I tried 89 octane in my ZL1 and was glad when it ran low so I could put 93 in it.
Old 07-28-2022, 08:25 PM   #5
LeonardS
There are no stations in North Dakota that sell 93, so 91 is the best I can get. I’m going to buy 55 gallon drums of unleaded 100+ octane and mix it.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 07-28-2022, 08:26 PM   #6
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
I use 91 in my V6 as well since it's the highest locally for me, or 93 when I find it. Never have put regular in it, either.
Anjilslaire is offline   Reply With Quote
Old 07-28-2022, 08:40 PM   #7
Gen6cyl
I used 87 for my first 18k miles then changed to 93,now at 34 k.Runs much better. I will only run 93.
Old 07-28-2022, 10:09 PM   #8
If the car is stock, you can pump lower than 93, but it will make the car run worse. Put proper gas in it (even 93 is on the verge, barely enough for full power, although maybe not so much on a stock SS).
Old 07-28-2022, 10:29 PM   #9
Devstrike
Devstrike's Avatar
This is why I wish there were stations with 93 near me. I am in Connecticut until August and for premium out here it's 93 and back home all I can find is 91. I haven't notice a difference in power but I just wish 93 was available where I live like they have in CT.
Old 07-28-2022, 10:39 PM   #10
BlueDog17
Drives: 2017 Camaro 2SS
The owners manual says less than 93 is ok to run, but less performance and fuel economy. I run all grades. IN my opinion, lower grades are ok if you are not pushing for performance- I.e. drive easy any grade is fine; push the throttle 93 is best
BlueDog17 is offline   Reply With Quote
Old 07-28-2022, 11:02 PM   #11
goata8
Drives: 2023 LT1 A10
I've always ran 93. Can't even remember the last time I saw a 91 pump but then again I really don't go looking.
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6
goata8 is offline   Reply With Quote
Old 07-29-2022, 07:53 AM   #12
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Pulls a lot of timing out of it due to the knock, loss of power. Even 93 in these engines can be a little weak. I know for a fact it'll run just fine on 87 though. Much less than ideal and not what should be done.
I've only got two options for 93 in my direct area. Lot's of 91 though and I won't run that any more, either.
Old 07-29-2022, 08:03 AM   #13
xplct
xplct's Avatar
Drives: 2022 camaro 2ss 1LE
If I had to run regular grade, I would get some octane booster to put in with it.
Here in Florida we run out of gas sometimes when a hurricane is coming, so I always keep a few bottles of octane boost on hand just in case there is no Premium available.
xplct is offline   Reply With Quote
Old 07-29-2022, 09:19 AM   #14
xqwisit23
Drives: 2019 Camaro 2SS Vert
Been 8 yrs since I moved to Canada from the US and the gas ratings up here are different than down south:
87 - Regular
89 - Mid Grade
91 - Premium
94 - Super Premium (only avail at Chevron)
xqwisit23 is offline   Reply With Quote
