Old 07-26-2022, 02:15 PM   #1
chisox05
Drives: 2022 Camaro ZL1
Do power stop pads destroy Brembo rotors
I really hate the brake dust like so many but I was wondering will switching to Powerstop Z26 pads ruin the Brembo rotors. Just got my car and only have 200 miles and cannot believe the dust. I ceramic coated the wheels which make them easy to clean but I have had to wash the rims 3 times already in 200 miles and just 10 days of owning.
I am not going to track it so I am ok with a little bit less brake power if it stops most of the dust. Any other low dust pad recommendations?
chisox05 is offline   Reply With Quote
Old 07-26-2022, 02:21 PM   #2
raptor5244
Drives: 2022 CT4-V Blackwing
You will lose some bite but many folks have switched to those pads without issue. The dust is annoying but my car is black so I have to wash it every week anyway.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 07-26-2022, 02:24 PM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I switched from the stock Brembo pads to PowerStop Z26 pads at about 400 miles (on the odometer), I now have over 6,700 miles, no issues (other than slightly reduced braking vs. the Brembo pads) but still plenty of braking for the street and about a 95% reduction in brake dust...
If you aren't tracking your car, I'd switch...
Old 07-26-2022, 02:28 PM   #4
chisox05
Thanks
Is anyone out there with Powerstop pads and higher mileage? I already ordered the Powerstops but saw a post on a ZL1 FB page someone with a hellcat had their brembo rotors severely worn down with just street use and the power stop pads.
Old 07-26-2022, 02:41 PM   #5
AZ_1LE
Drives: 2019 ZL1 1LE
GLOC GS-1 (street pads) work awesome, I've had them on all of my Camaro's. No change in brake performance, way less dust.
https://www.greeneperformance.com/collections/chevrolet
Powerstop Z26 pads suck.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 07-26-2022, 02:56 PM   #6
Juniorss
Juniorss's Avatar
Drives: 2022 SS 1LE
Whose pads are they rebranding?
I have had Powerstops on my Hellcat, my Ram, and my dad has had them on his 392 and Scat Pack, all without issue. Yes there is less initial bite, but they work perfectly fine for street use, and stop pretty damn well if you need to step on them.
2022 SS 1LE - Summit White
2023 ZL1 On Order (Unless I supercharge the 1LE first...)
Juniorss is offline   Reply With Quote
Old 07-26-2022, 03:05 PM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Ive had the Z26 on my 1LE for atleast 30K miles and 3 years and there's no unexpected wear or anything else going on with my rotors.
Old 07-26-2022, 03:29 PM   #8
chisox05
Great thanks. I have Power stop rotor and pads on my truck so I know they are nearly dustless. I didn't think they could damage the Brembo rotors. I always thought Brembo rotors were a harder higher quality material than a standard steel rotor.
Old 07-26-2022, 04:34 PM   #9
mliebs
mliebs's Avatar
Drives: 2022 ZL1
Take this with a grain of salt but I replaced my C7 Z51 Brembro pads at 10k miles with the Z26 pads. Starting at around 15k miles I would get a pulsation (steering wheel would shake left to right) when I braked and it felt like warped rotors. After doing a hard stop it would go away but it kept coming back. I'm not sure if it was build up on the rotors or what but I didn't like it. I did a proper bedding of the brake pads when i installed them but for some reason they didn't like my car. I thought about replacing the Brembos on my 22 ZL1 but decided I'm just going to live with the brake dust. About a month before I sold the car I had it serviced and the shop told me the rotors were starting to get a little runout on them.
mliebs is offline   Reply With Quote
Old 07-26-2022, 08:32 PM   #10
Xelor
Drives: 2022 ZL1
Don’t do it. Leave the pads alone.
Xelor is offline   Reply With Quote
Old 07-26-2022, 09:53 PM   #11
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Powerstop Z26 pads have been on for over 2 years, no issues. Haul me down from 146 MPH at the end of a quarter mile run, can’t be that bad lol.
Old 07-26-2022, 09:56 PM   #12
SATINSTEEL1LE
Drives: 21 ZL1
I thought the stock rotors were GM and only the pads and calipers were "brembo"...?
SATINSTEEL1LE is offline   Reply With Quote
Old 07-26-2022, 10:00 PM   #13
AZ_1LE
They're sons of the guy who started Carbotech. They took some of the pad formulations but made them better and are my go-to now for street and track pads.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 07-26-2022, 10:18 PM   #14
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Well the pads are made by Ferodo, but, IIRC, have Brembo branding on them. I don't believe they say Ferodo anywhere on the pads.
YouTube
