Old 07-23-2022, 09:39 AM   #1
Hankaro
Hankaro's Avatar
Drives: 2022 Camaro 2SS
Waterless Touchup?
What products do you use for waterless touchups? As in you washed your car yesterday, but now there's a bug splattered on it. (Needs to be waterless...no driveway hose washing allowed in my township.) TIA.
Hankaro is offline   Reply With Quote
Old 07-23-2022, 09:45 AM   #2
xplct
xplct's Avatar
Drives: 2022 camaro 2ss 1LE
Ive always used Honda spray cleaner and polish. But this may change after I get the ceramic coating done.
xplct is offline   Reply With Quote
Old 07-23-2022, 10:16 AM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Here are two of many threads on the topic:
https://www.camaro6.com/forums/showthread.php?t=484594
https://www.camaro6.com/forums/showthread.php?t=490786
“Glen e” and “KirkH” have some great threads on the topic. I use ECH2O and have been happy with the results. You might want to search the Cosmetic Maintenance section for other suggestions.
Old 07-23-2022, 11:32 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
For bugs & bug-guts, and tar: Turtle Wax Bug-n-Tar remover and an Eagle Edgeless plush microfiber towel. Drip it on and let the stuff soak for AT LEAST 60-90 seconds. Never drag bug parts across dry paint. The carapaces will swirl. Roll your towel and/or Blot + pinch them off.
Afterward, quick detail the area with "Magic Elixer*" and a clean same towel. Just enough soap from the Ech20 to take care of the terpentine residue from the TWB&TR and reload to restore the hydrophobic.
* Magic Elixer:
1 part Carpro Ech20
4 parts Carpro Reload
20 parts Distilled water.
Old 07-23-2022, 12:17 PM   #5
22SS1LE
Drives: 2022 1SS 1LE 6M
Optimum rinse less wash would be a good choice.
Great lubrication for safe cleaning.
No need for a hose. you can fill a bucket with 3 gal of water in the house and wash the car. Put some in a spray bottle and pre treat the car before you put a microfiber mitt to it.
That should give lots of lubrication for safe washing
All in all use a total of 3+ gal and no hose needed
I hardly ever do hose washes anymore and 90% of car washing I do is with ONR. If it is really dirty I will give it a pre rinse and you could do a pre hose at a DIY car wash if it was to dirty to start with ONR
ONR is the original and was created by Dr. Ghodoussi he helped to create modern clear coat. So he knows a thing or two on cleaning it
I recommend the Optimum sponge over MF wash mitt
https://www.autoality.com/store/pc/O...ge-92p7520.htm
https://www.autoality.com/store/pc/O...mula-92p80.htm
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 07-23-2022, 12:44 PM   #6
Hankaro
Hankaro's Avatar
Thanks for the responses so far. But just to be clear, I'm looking for something to spot clean small areas in between full washes.
Old 07-23-2022, 02:46 PM   #7
22SS1LE
ONR again.
you can mix it up as a quick detailer in a bottle.
Use as a quick detailer and clay bar lubricant, mix 1oz of ONR to 16oz of water
Old 07-24-2022, 07:12 AM   #8
NashZL1
Drives: 2022 Camaro ZL1
I use Meguiar's Waterless Wash. I buy it by the gallon when available.
https://www.meguiars.com/automotive/...26-26-oz-spray
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 07-26-2022, 05:55 PM   #9
VINCETHEGIANT
Drives: '20 SS/1LE
the trick is really have a good coat of wax on before the splat..then soak it in your favorite spray and let it soften up and it should wipe rite off? works for me every time.
VINCETHEGIANT is offline   Reply With Quote
Old 09-19-2022, 05:39 PM   #10
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
This is what detail sprays are for. Plenty to choose from, pick your favorite. But realize, if you drag dirt or debris without proper lubrication, you scratch.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 09-20-2022, 08:13 AM   #11
joekd
Drives: 2018 Camaro SS vert
Chemical guys V07 quick detailer, have always gotten best results using it
I buy it by the gallon, keep one smaller spray bottle in the car for quick car show touchups and a much larger spray bottle on my work bench for garage clean ups
As mentioned use plenty of spray to prevent dry wiping
joekd is offline   Reply With Quote
Old 09-20-2022, 08:40 AM   #12
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Yeah sounds like you just want a good detail spray OP. There are so many out there. My last few bottles have been Auto Fanatic 007 Gloss Enhancer. I'm a fan, but there are lots of great options.
YouTube
Old 09-23-2022, 01:45 PM   #13
Robby5323
Drives: 2022 LT1 Chevrolet Camaro
Poorboys works great for me. I've been using it for years. My cars hardly ever see a hose and a bucket. https://www.autogeek.net/pbsaw128.ht...ent=Ad%20group
Robby5323 is offline   Reply With Quote
Old 10-01-2022, 10:43 PM   #14
Grumpy1
Grumpy1's Avatar
Adams waterless wash or detail spray….
Grumpy1 is offline   Reply With Quote
