BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
ZLE cutting power on track
As the title states. Tight section of a particular track the car was cutting the throttle on me abruptly for a split second then resumed as normal. I was in track mode default.
Have any of you experienced this? Thank you for your input in advance
2021 ZL1 1LE
Auto |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
It may be pulling timing for some reason.
Questions: Was was your MAP? How was your IAT? False knock caused by modifications? Oil Temps? Coolant Temps? If you have HP Tuners you might want to log the data and review it. |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
Saw another post recently for the same issue, they replaced the fuel pump assembly. Log it to see if you lose fuel pressure.
https://www.camaro6.com/forums/showthread.php?t=554769
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
If you were in Track mode with no PTM setting applied, that alone is not enough to enable you top put power down under hard acceleration and high Gs. You also need to set the PTM Mode correctly for your driving level.
If you're advanced you should be in PTM RACE Mode, or turn stability control FULL OFF, to not have the stability control power-cut under different conditions. Even in PTM RACE it will interfere, but if you hit the apexes right it will do it in a way that uses the E-Diff to put power down very effectively for hard acceleration out of turns at FULL throttle, while cars without it depend on a lot of skill to maintain control and not oversteer. So maybe try hitting some turns hard at lower speeds with everything FULL OFF (depress stability control button for 10+ seconds), and see if you still get any cut out. After ruling this out, try PTM Race at higher speeds in those turns to add some safety but still enable very fast laps. Also, do you have a t least 1/4 tank when it happens? Shouldn't be a problem in ZL1 but worth checking. |
BanHamWatch
Thx all for replying yes interestingly it did it on the same section every time which was hard acceleration out of a reduced radius turn. As for mods one thing I forgot to turn off which I normally do is my Sprint controller for the throttle. I’m wondering if the faster throttle blade setting made the car intervene under that particular section. Car was 1/2 tank fuel.
2021 ZL1 1LE
Auto |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
It's not doing it on the straights but in a corner? Where at in the corner is it happening? As you are rolling into the throttle or once you go full throttle?
If you're not in PTM mode, the nannies are still in full force and could be cutting power to keep you from spinning out. You were just in track mode and not comp mod or PTM correct? |
#7 | |
#8 | |
BanHamWatch
2021 ZL1 1LE
Auto |
#9 |
![]() Drives: ZL1 Join Date: Jan 2019
#10 |
#11 | |
Gotta be a little more careful/ patient with this big car and tight, slow corners. |
#12 | |
One of these days I am going to get the courage to turn everything off. |
#13 |
BanHamWatch
I’m back at the same track at the beginning of August. I will ensure I have the throttle booster off this time and if that doesn’t work will continue down the line taking off more intervention using the PTM modes. If that all doesn’t work I will need to look at possible mechanical issues however I highly doubt that’s the issue as it was repeatable and I was driving hard on many other areas of this track without issue.
I actually have the PDR video I can put a link too when I get back from vacation that might shed some light? I just don’t have access to the car now till August. Also I read that whole thread provided were buddy was getting stumbling and had fuel pump issues. I had no stumbling anytime it was a complete fuel cutoff event I feel or power cut then just resumed like nothing happened.
2021 ZL1 1LE
Auto Last edited by Chippy; 07-22-2022 at 09:35 PM. |
#14 |
Are you at half a tank or less and at a turn? It's probably fuel surge.
