Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Belt length for 10% lower and stock upper
Does anyone have the info for a gates belt for 10% lower and stock upper? Should I use the HD belt form gates or the rpm belt? Any help would be appreciated. I looked online and here and can’t get a confident part#.
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
What size is that, an 8.8" pulley? You gotta be more specific on the sizes and stuff to get a more accurate recommendation or even a recommendation at all.
758 HP/ 804 TQ |
Red Bull
Yes it’s an ATI 8.8 lower
Super Stock
I just need to confirm. This 8.8 pulley is for the supercharger drive correct?
758 HP/ 804 TQ |
Red Bull
Yes it’s the super charger driver pulley that mounts to the crank
Super Stock
I can see how you're having trouble finding the right belt for it. Do you know the original supercharger pulley size by chance? I know those run a K080828 belt which is effectively lengthed at 82.80".
758 HP/ 804 TQ |
#7 |
Super Stock
You know what. The ATI 8.6 pulleys use a K080839 belt so that should work on yours as well given the 8.6 pulley is literally just .2" smaller than yours. I would pick one of those up in the RPM size and you'll be set to go.
758 HP/ 804 TQ |
#8 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
Just an FYI...Regarding the RPM belt...do your research. These belts do not stretch. Do not over tension. I have no belt slip issues now.
#9 | |
Super Stock
Granted, any belt is capable of snapping, but that is an inherent risk of running belts in the first place.
758 HP/ 804 TQ |
#10 |
Got it. My Procharger tensioner is manual. I just snugged it up.
#11 | |
Super Stock
Pros and Cons. I sort of wish we had a manual but the spring loaded ones are super convenient too. Grass is always greener right? Lol.
758 HP/ 804 TQ |
#12 |
![]() Drives: 19 ZL1 Join Date: Jan 2019
I have a the AIT damper 8.650, its the 8% overdrive pulley.
8 Rib, 84 3/8 think the napa number was 25-080839HD |
#13 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
I believe the 39 was the same belt I used with an 8.8 lower, stock upper
#14 |
Red Bull
Thanks guys. I actually had the 8.8 ATI which is for the corvette dry sump and won’t work. I ordered the 8.6 and I have a stock upper so I assume the belt I need is the 25-080839HD.
