![]() Drives: 2020 Camaro 2LT Join Date: Apr 2022
2022 SS / NPP
Everyone,
I had a 2020 before my SS, and it had the NPP as well. I cut the resonators out of the last one (was a v6 with NPP) and had a x pipe installed. I am waiting to keep the NPP on my v8 and do some mod similar to this to enhance the sound of the exhaust, but keep the NPP in tact. Can a resonator delete be done to this as well? Wasn’t sure if the v6 to v8 with NPP was drastically different. SMOG is not a concern either, so shoot me with your ideas. Thanks! |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Yes you can delete the resonator on these cars. It will increase sound a tad but not much. Your local muffler shop should be able to do this and it wont cause a Check Engine Light.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
"resonator"...?
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
I do not believe they are resonators, I am fairly certain they are secondary catalytic converters. Pending emissions checks in your area, you can remove them. Not sure I recommend or not, I have not done so.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
![]() Drives: 2024 Black ZL1, M6 Join Date: Mar 2014
Just had my secondary cats removed this morning. Slight increase in sound. Noticeable for sure. I like it better.
In CA? Nice, didn't know you could get away with it over near LA.
#7 |
![]() Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
To be fair - removing them is one thing, passing a smog/emissions test after they are removed is another...
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
#8 |
PaPa Smurf
This is from another user on here. If gutted this way and seal welded back together is will appear that they are still original and complete and won't throw a code. Secondary cats are generally only used during the warm up of the primaries.
#9 |
It will still pass smog. A shop has to put it up on a rack to see they are missing. I’m not worried about it I have ways to get it done and if I have to put them back on before it’s 45 min. Job. The car does not need smog for 6-8 years.
