![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
1LE Suspension Tweak Update
I got some bits installed today. The car feels sharper, and the rear feels nice and tight now. I can't wait to see how things go at the track on Monday.
- BMR Tunnel Brace - BMR Front Swaybar Linkage - Lowered Front 3mm (Adjusted Preload 2 turns) - Installed GY3R - Rear Cradle Braces I noticed that the GM bits that were removed were not poor quality, but they were basically hollow metal tuned to be rigid at the edges. The BMR stuff seemed to have the joints more dialed in for rigidity with welds for reinforcement. Apex SM-10 18x11 and 18x12 also arrived but the slicks won't arrive till Tuesday so the track day will be done on the GY3R. ![]() ![]() ![]() Stock vs BMR ![]() ![]() ![]() Stock vs Aftermarket ( No deflection in the BMR unit) ![]() Before: Stock Sway Bar End Link ![]() After: BMR Sway Bar End Link (not preloaded - Will revisit that later) ![]() When the guys at the shop mounted my GY3R we found my rim was bent on the inside. Called in a favor and got it corrected a few minutes ago. Tipped the guy a guap for taking care of me. Was done in less than 8 minutes. Didn't even have to take the tire off. Amazing. Didn't even know this machine existed. Lol ![]() ![]() ![]() The car is waaaay more responsive and feels much "Tighter" in side to side transitions after the cradle brace install. The rear sway bar links are going on tomorrow. I like the fact that you can elongate the SB End-links and preload the Sway Bar making it even tighter. We added a lot more adjustability into an already adjustable chassis. |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Interesting. Following to see what comes of your rear end links but that cradle brace is what is leaking my interest for sure.
758 HP/ 804 TQ |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
Are the rear cradle braces BMR also?
Yes sir. I was a bit rushed because the shop was busy and they took me in without an appointment.
Ideally I would have liked to weigh the items and also do a deflection test with a gauge, but maybe I'll get to it over the winter when I change the GM stretch bolts. Last edited by NG329; 07-16-2022 at 11:11 AM. |
front slicks showed up and the rear sway bar links:
![]() ![]() ![]() ![]() ![]() If the rears are in similar condition, these can probably squeeze in 3 track days. Can't beat that with a stick for $700 for the set of 4 plus shipping. |
#7 |
Just got back from installing the rear sway bar links. Zero body roll now. No shimmying at all. Took my mechanics on a test drive and they were blown away.
#8 |
Based on what I can feel so far, I don’t think there’s a need to buy the control arms and toe rods. The SB links, cradle braces, and drivetrain tunnel brace are the sweet spot. It feels absolutely perfect!
Trust me guys! Also we noticed that the left rear sway bar had some flex/play in it with the stock linkage. It has since been eliminated. |
#9 |
NJMP Thunderbolt Update
SESSION 1 Spun out on first lap. Slick track, car is oversteery. Best lap 1:35 due to cut session. Session ended when tires came in. Local racer said I should consider softening rear sway bar. I told him I will try this setup for one more session first. |
#10 |
Session 2 Update:
I think I was the fastest guy on track. Ran a 1:31.0 consistently in heavy traffic. Car feels perfect! I’m definitely hitting 1:29 today or maybe quicker. |
#11 |
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Sounds like you are having fun! Go get that 1:29!!!
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
#12 |
Camaro BITCHES!!!!!
#13 |
Session 3:
Ran a 1:30.66 with traffic. Had an instructor in the car. |
#14 |
Session 4:
Lots of traffic. Best time 1:31.x Tire pressures creeping up. |
