2SS ickle
Drives: 2022 ZL1 1LE, 2022 2SS 1LE Join Date: Mar 2022
Stock exhaust suitcase
So I'm just having an issue with spending $3000 to get virtually the same sound from a Borla or Corsa aftermarket exhaust, for me it's just about sound not weight.
But I did hate the way this HUGE chunk of metal looked from the rear so I thought this may help hide it which it did for sure, 1200 degree high heat paint bomb did the trick.
2022 2SS 1LE / Vivid Orange A10 (delivered 10/08/22)
2022 Lexus ES350 F Perf, white/red/black leather 2022 F150 Lariat Sport Rapid Red 2022 ZL1 black/black, MT, (SOLD) 2023 C8 Corvette, 2LT / Amplify Orange, Z51(SOLD) ********** |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
I want to do this as well. Let me know how it holds up. Did you prep the surface at all or simply spray? What brand did you use?
2SS ickle
Rubbed the tank down with pure rubbing alcohol used Krylon High Heat Max 1200 degree
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
That's a great move that only a few people have done, I like it!
I am with you on costs still plan on adding a Borla S-Type but the Axleback not the catback. The stock system is too damn raspy for me. I don't plan on spending even $2K, some sponsors have great unadvertised pricing and you save $ with the axleback already. If sound is all you're after, you dont need the catback. AWE also sounds amazing, and is even cheaper(no NPP function).
J-Rod Built and Matt@FSP Tuned |
You won't make anymore power with aftermarket and you did a good job on painting it. Looks real clean, I'm gonna do that myself.
#6 | |
2SS ickle
#7 | |
OP - nice work. You won't regret painting the muffler. I've attached a photo of the job from back in 2016 to show the muffler and exhaust tips.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Axleback's are much cheaper than a full catback and will still drastically change the sound.
#9 |
Thanks for the input. I am so doing this as well. I dont plan on changing my OEM NPP but will add Headers. They are sitting in the garage ahhhhh
#10 | |
#11 |
Drives: 21 ZL1 Join Date: Feb 2022
Looks freakin amazing. I did this with the rear cross member on my C6. It was natual metal finish when the rest was all black under there. Chevy even went as far as painting just what you could see of the factory mufflers flat black, but stopped half way up them where they tucked behind the bumper. But they did not paint that cross member. So dumb. But this looks great. Thats a lot of area to cover though and I'd be scared of overspray. But this is great. If I ever have mine off, I will do this for sure.
#12 |
I just cleaned them thoroughly first. Then I cut the toes out of some old socks and slipped the socks over the tips and taped off the very edge of each tip plus taped off the valence panel to control overspray. Then I used the same flat black high temp paint I used for the muffler. This has held up remarkabley well. I have never cleaned the inside of the tips since I painted them. I just took this picture and here is how they look after six years.
#13 |
![]() Drives: 2023 LT1 A10 Join Date: May 2017
Those both look great!
I've always debated doing mine...I wonder if anyone has ever polished it instead? Probably would need constant upkeep...the exact opposite of what I want lol
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6 |
#14 |
![]() Drives: 2018 Camaro SS vert Join Date: Oct 2020
Did this on my wifes Cadillac SRX, first time I did it with just a scuff lasted 2 years, redid it again with better wash, degrease, scuff and it still looks good
