07-13-2022, 12:09 PM | #1 |
Drives: 2019 2SS/1LE Shadow Grey Join Date: Nov 2015
Side skirts
I have a 19 1LE with eos T6 style skirts. These I’d have to say do not contour very well and even with higher quality tape don’t stay on the rocker worth a damn…. Looking for some better options. I have them screwed underneath but nothing through the sides of the rocker as these are open underneath not closed in. What are people using that actually are good contoured to the body lines and rivet underneath and tape on the sides of the rocker… are IKON or the ZL1Addons any good? Don’t really want to go all the way to $7-800.
07-13-2022, 01:30 PM | #2 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
I suggest OEM, the GM parts fit perfect, are attached with rivets and adhesive, solid (not open on the bottom), no problem holding up at 150+ (in proper location of course!) and of course, they match the 1LE ground effects perfectly.
My opinion, many threads on this, but OEM is the best option for me. |
07-13-2022, 02:20 PM | #3 |
Under OEM you’re likely looking at ACS from a quality standpoint. After that C7 Carbon is ok but I had minor issues with the passenger side o my SS when I had it. It sorta becomes sketchy under that with hit or miss fit/finish.
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
07-13-2022, 03:08 PM | #4 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
07-13-2022, 09:20 PM | #5 |
So you just went and out a whole 10+ holes in the side of your rocker as well as the bottom? If you ever take them off your going to have aton of homes down the side of your car. I also have the t6 style not the zl1 so mine don’t go up the rocker as far as yours do.
07-13-2022, 09:28 PM | #6 | |
Worst case the rocker panels themselves can also be replaced or swapped out for the integrated ZL1 rocker+skirt combo part.
07-13-2022, 09:31 PM | #7 | |
Look at some of the corvettes and you will see that they also have the AERO parts like the side skirts and spoiler extensions riveted on from the FACTORY. They were not foolish enough to believe like some of the LOCAL GM dealers that apparently were too lazy to follow GM assembly instructions on the 1LE skirts for instance that specifically call for the skirts to be RIVETED on. AERO pieces are NOT going to stay on at 180MPH with just double sided tape and will CERTAINLY NOT in any case of an impact If you can take your hand and you can push the aero piece away from the body with just a gentle push, then your aero piece will fail. Do a search on Camaro6 and you will see where guys have lost their side skirts because their dealer IMPROPERLY installed factory side skirts (just tape) on the HIGHWAY at speed with NO IMPACT due just the force of the air pressure. IF you dont believe this, stick your hand out your window at 100MPH and see what happens.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 07-14-2022 at 04:17 AM. |
07-14-2022, 05:43 AM | #8 |
Faster!!!
Rivets are a must! OEM uses many of them, an under skin that rivets to the car. Adhesive and more rivets for the outer skin, then finally, more rivets underneath. The adhesive, 3M, essentially welds the two skins into one solid unit.
All completely invisible unless you are under the car. They are NOT coming off!!! Like the 1LE factory ground effects, they are functional, not cosmetic, and must be very secure. All IMO of course. You shake the entire car by grabbing one, solid as heck! |
07-14-2022, 09:50 PM | #9 |
Thanks for the info!
06-27-2023, 10:49 AM | #10 | |
Drives: 2017 Camaro I4 Join Date: Feb 2020
06-27-2023, 02:51 PM | #11 |
I used PAINTERS tape just to hold the skirts in place. The RIVET will push the shirt tightly to the body when you install them. I used a rivet gun that was attached to an air compressor which applies the pressure to the rivet more evenly and with more force than a manually operated rivet gun.
07-01-2023, 03:47 PM | #12 |
Central PA Camaro5 Club
Drives: Hot Wheels Join Date: Apr 2009
I went with RPI side skirts and they fit perfect and are not expensive
Hot Wheel SE # 343
