Old 07-13-2022, 11:32 AM   #1
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
1LE Wing Removal - Dents/Deformation
So my the replacement wing for my car (original was damaged in transport) finally arrived so I needed to remove the original.
In doing so I believe I must have rocked the wing (I didn't think I was being particularly aggressive with it) while heat gunning the adhesive to release it under the stanchions.
Any thoughts on how I could fix this (see photos)? It's basically the same on both the outboard sides and a little less on the center.
rlarsen462 is offline   Reply With Quote
Old 07-13-2022, 12:59 PM   #2
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Damn that sucks. Maybe try a dent repair guy but it might be tough to get that line straight. Worth a try. If not I would just buy a new trunk lid and have it painted.
pauly1119 is offline   Reply With Quote
Old 07-13-2022, 01:07 PM   #3
MatthewAMEL
MatthewAMEL's Avatar
Should be pretty easy for a PDR.
Those holes are in good proximity to the bends.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 07-13-2022, 01:40 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Why are you concerned about the holes if a spoiler goes over it? I'm not asking out of smartassery I'm asking out of genuine curiosity.
758 HP/ 804 TQ
Old 07-13-2022, 03:27 PM   #5
rlarsen462
Sell Low, Buy High
It's not the holes I'm worried about, those are for the wing, it's the deformation behind the holes that I caused removing the wing, it will cause a gap at the back of the stanchions if I don't have it repaired first.
Quoted $500 for a well reviewed and reputable local PDR outfit to repair, sucks but it is what it is...
Old 07-13-2022, 03:28 PM   #6
rlarsen462
Sell Low, Buy High
This will be my fallback...does anyone have the part # for the trunk deck with the correct ZLE wing hole spacing predrilled (or do those always have to be drilled after the fact?)?
Old 07-13-2022, 03:39 PM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I would try the PDR method first before buying a new trunk lid.
Old 07-13-2022, 04:14 PM   #8
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I would think a 1LE lid would come with the holes already in place. Check eBay sometimes you can get lucky and find one the same color. I did that with a SUV last year, found a fender the same factory color and just bolted it on.
Old 07-13-2022, 05:55 PM   #9
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
PDR guy will fix that in a few minutes.
Dan82679 is offline   Reply With Quote
Old 07-15-2022, 09:57 AM   #10
DylansZLE
DylansZLE's Avatar
Drives: 2022 Rapid Blue ZLE
I would be willing to bet that happened when the wing was damaged and the supports hid the dents. When I damaged mine earlier this year that happened if you recall the pictures I posted, but mine were more severe.
2022 Rapid Blue ZL1 1LE order ZNWPCX
Ordered - April 8, 2021 // 2000 - July 30, 2021
3000 - August 3, 2021 // 3100 - August 6, 2021
TPW - August 30
3300 - August 21 // 3400 - August 21
3800 10/18 // 4150 Oct 22
6000 November 1st
Instagram: dylanszle
DylansZLE is offline   Reply With Quote
Old 07-15-2022, 12:19 PM   #11
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
I would have to agree with this. No way OP did the dents by simply rocking it back and forth for removal.. If thats the case, the trunk would not be able to stand the downforce regenerated at high speeds.
Old 07-15-2022, 05:29 PM   #12
rlarsen462
Sell Low, Buy High
Yeah, dang that's a good point, didn't really think about that and didn't notice or register with me at least when I was detailing the car but it was probably there on delivery...for obvious reasons I was much more fixated on the damage to the $6K wing lol.
Either way, the shipper did replace the wing with new factory unit (how the hell he got one is a mystery but it did take 5 months), and actually is covering the PDR costs as well even though I told him it was probably my fault, as I thought it was at the time.
I guess we will know Tuesday if it comes out all right and I can mount the new wing.
