![]() Drives: Camaro 2SS 2017 Join Date: Jan 2022
P1SC VS D1X
Hello everyone i definitely feel like i made a big misstake choosing the P1SC. I have now ordered expensive FIC30s, LPE HPFP, 32% lobe cam so i think i have plenty fuel but i feel like its going to be limited now by the P1 supercharger. I think im going 3.4 pulley and i bet it gives alot of boost but i read that the D series or even better F series would keep it going cooler. What is you guys opinion? Maybe go for more E% and that will help? Will a GT35 42% cam help me alot? Very thankfull for every tip.
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT 2Forge 19" wheels daily, Forgestar D5 17" for track |
#2 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
#3 | |
![]() Drives: 2018 1SS 1LE Join Date: Jul 2012
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
Iirc you can send it in for a D conversion if you feel the need.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror ![]() |
P1sc is efficient in the 7-8psi range. Above that it starts to climb above it's efficiency range. You can cheat that by spraying meth injection and it will cool the boost which will allow it to go further. Even the P1x starts to crank some heat out once above 9psi. Imo a D series supercharger is the sweet spot for most builds not using meth.
I would Contact BRC race works and get a 43% lobe from Ryne Cunningham to maximize the potential of your LPE HPFP. 32% lobe will work but you might be mixing around E60 to keep the fuel system demand in check. Nothing wrong with E60 as it's the sweet spot for Ethanol on most builds. You just have to deal with mixing the stuff which imo is not that difficult. But either way, since you spent the money on fuel system you might as well get the right cam lobe to fully utilize the systems potential.
#6 | |
#7 |
It would depend on the percentage of ethanol you attempt to use. Pump e85 only, probably not. Blended pump 93 and e85 as King mentioned to you to make e50 or e60, yes it will support it.
#8 |
That’s to bad. Maybe a dsx lowside could help? And yes i have a set of drop in pistons and rods from GPI on order, just waiting for the compstar rods to get ready which I feel like is taking forever lol. Not GPIs fault though
#9 |
Goals is not really set yet. 750 ish would be great. I just got obsessed with the fueling I guess lol and I feel that i have focused to much about fueling and am forgetting that there are other important parts to the build lol
#10 |
![]() Drives: 22 LT1 Join Date: Apr 2022
I talked to procharger last week before I ordered. He recommended going with the P1x. Little more efficient bearing setup than the P1 and D1. He said they really work good on the modern muscle cars especially with the 8 and 10 speeds. I also got the stage 2 intercooler. He highly recommend that.
#11 | |
#12 |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
I currently have the P1X and stage 2... no complaints except now in the heat. The IATs really climb and the intercooler doesn't pull enough heat. If I had it to do over... I'd probably have gone with D1X... or a Maggy... but I've heard there are tradeoffs so.... ???? P1X with more effective intercooler options would be great.
#13 | |
#14 | |
![]() Drives: 21 Lt1 Join Date: Dec 2016
