Old 07-01-2022, 08:35 AM   #1
jd4523273
Drives: 2006 Chrysler PT Cruiser
Mice Living Under Center Console
Hi, I don’t know if this has happened to anybody, but I thought I would share it. I was removing my center console to replace a damaged vent on the climate control unit when I noticed a mice nest made from the underside carpet fibers under the center console. What should’ve taken an hour took four and a half hours, I had to remove both the passenger and driver seat and all carpets just to make sure there weren’t any mice around, I also wanted to make sure there was no other fecal matter anywhere else besides on the center area. If anybody can tell me what steps to take in the future to avoid another similar situation, I would greatly appreciate it.
jd4523273 is offline   Reply With Quote
Old 07-01-2022, 08:37 AM   #2
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
If your car sits for a while, use mothballs in a sock.
Mothballs can be hung under the front of the hood as a repellant; however be sure to not place near the windshield washer area (where fluid is expelled) or the mothball smell will permeate the interior of the car.
Old 07-01-2022, 09:35 AM   #3
LeonardS
I would keep sticky traps(lots of them)and mouse poison in your garage or where you store your car. I’m not a fan of moth balls because they make everything stink, even when they are outside your car.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 07-01-2022, 09:54 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I’m not a fan of using poison because the mice can die inside the car.
Here are a few threads about mice:
https://www.camaro6.com/forums/showthread.php?t=529008
https://www.camaro6.com/forums/showthread.php?t=529323
Old 07-01-2022, 09:58 AM   #5
LeonardS
That’s true. Our pest company at work always said “bait on the outside of the building and trap on the inside”.
28 Ford Pickup
Old 07-01-2022, 10:05 AM   #6
ctrlz
I prefer snap traps to glue traps. Not a fan of mice (which are often really voles), but glue traps pretty cruel. The rodents can be released from the glue with about 1 tsp of vegetable oil if you are interested.
I use a glue gun to affix two pieces of dog kibble to a snap trap. Done well, they can't chew or steal the bait without triggering the trap.
Old 07-01-2022, 10:36 AM   #7
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I keep a container with about a cup of moth balls in it I take top off and put it behind front wheel when I park at home.Never had any varmint problems when doing this.I used a glue trap once , the mouse chewed it's front legs into just above it's feet.
Gen6cyl is offline   Reply With Quote
Old 07-01-2022, 11:15 AM   #8
DT10
DT10's Avatar
Drives: 2015 2SS/RS
So…. Use bait to bring them to your house and then trap them inside? Thats some job security!
DT10 is offline   Reply With Quote
Old 07-01-2022, 11:20 AM   #9
LeonardS
LOL….. I think the mice are already around in the Fall. Kill them before they get inside for Winter
28 Ford Pickup
Old 07-01-2022, 11:41 AM   #10
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Poison and snap traps in the garage. The best poison is from professional pest control. I use snap traps in addition to poison because it seems voles go for the snap traps year round.
Use plastic snap traps, not the old fashioned wire kind. The plastic traps are easy to open and re-use. They have little bait cups, and a tiny drop of honey is the best bait.
I have never used mothballs because who wants that smell in the car?
Old 07-01-2022, 11:43 AM   #11
Gen6cyl
Can't smell in car when you put on outside.
Old 07-01-2022, 01:38 PM   #12
PostalLDMC
PostalLDMC's Avatar
Drives: 2022 2LT RS Convertible
Put some peanut butter on the snap trap plate. With them licking it off it set the trap off. I use them outside it an old coffee can. They can smell the peanut butter and walk in never come out.
PostalLDMC is offline   Reply With Quote
Old 07-03-2022, 05:51 AM   #13
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Go to the local pet groomer and get a bag of dog hair, put in cut and small knotted panty hose bags and place around where/what you want them to avoid.
Warrior102 is offline   Reply With Quote
Old 07-03-2022, 08:18 AM   #14
wwiiavfan
Drives: 2017 1SS Hyper Blue
When we park cars in the fall, we put a “moat” of dryer sheets around the car. Can’t say with absolute certainty that it works, but no rodents yet in 5 years.
wwiiavfan is offline   Reply With Quote
