![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Plugs.. Might switch back
Curious if you guys are running Brisk Silver tips or NGK Titanium plugs. Also, did you go 1 step or 2 steps colder?
My original shop did the NGK 1 step colder , but my last tuner switched them to the Brisk 2 steps colder.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
How much boost are you running? I’m at 10lbs on stock pulleys and still in stock heat range on NGK plugs.
15 lbs
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I would run heat range 7 or maybe even 8's considering the power you are running. Considering the power you are working with here, I'd be more inclined to say you need heat range 8's.
I run NGK Ruthenium HR7 plugs, but I'm making somewhere in the high 5's to low 600's as far as power goes. Rule of thumb is 100 - 150 HP is the power window per each step in heat range until the next step up is needed.
758 HP/ 804 TQ |
I just looked up the ones in there now and they are the Brisk RR12S
#6 | |
Super Stock
![]() ![]() Equates to NGK heat range 8 plugs. I noticed the Brisks are non projected tips, are you intent on running that brand?
758 HP/ 804 TQ |
#7 |
No, not married to Brisk. Just recommend by last tuner. Unfortunately I have no idea what gap to run either as I didnt install either set.
#8 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
I'm running and satisfied with Brisk RR14S. Running around 15psi, gapped to 0.029" (from the stock 30-31 ish)
#9 | ||
Super Stock
And don't try to gap if you don't have the special tool for it on these platinum/ iridium/ ruthenium plugs or else you will scrape away their special coatings and make them no better than a copper plug. As for plugs, I've personally never ran a Brisk so I don't have a leg to stand when it comes to my experiences with them, but have nothing but stellar experiences with NGK. I was going to recommend you NGK Ruthenium's but they don't offer anything in the heat range you need in the spec our plugs come in, I run a LTR7BHX plug, I like them because they offer better knock resilience than their iridium counterparts and they have the projected square tips (PSPE) but 7's are the hottest ours offer. It's a toss up with what you want to do, but run an 8 in NGK (or a 12 in Brisk) and you should be good to go.
758 HP/ 804 TQ |
#10 |
Petro-sexual
Jannetti has said he runs as much as .040 as far out as 14-pounds on well-tuned set-ups. While I'm not making the smoke as much as many of you guys, I'm around 15-16-psi regularly, and run a tiny bit more than that with no issues. Again - not quite the same power, but around the same boost.
#11 |
0.030 is stock LT4 gap size, not sure why you'd go out to 0.040". That size (0.040") is the LT-1 stock gap size, a NA motor.
#12 |
I don't see the need for a 8 heat range on a stock compression LT4 even @ 15psi. A 7 gapped around .030 should be fine.
#13 |
Appreciate all the feedback. I will pull one out and see how it looks and if i want to switch back to the NGK. I am a little concerned with the 2 steps colder fouling easier or at least more carbon build up. I will be curious to see how they look.
#14 | |
Petro-sexual
The bigger the flame, the better, and the better drivability, from what I've seen. I can attest to this experience, too.
