Old 06-27-2022, 10:49 AM   #1
zepol9
Drives: 2016 Camaro 2SS NGM
valley cover / fuel lines
ok can i still use the stock valley cover even though i deleted dod also have the lt4 fuel pump and feed line should i change all 3 hard lines or just the feed line
zepol9 is offline   Reply With Quote
Old 07-03-2022, 11:41 PM   #2
zepol9
Anybody?
Old 07-06-2022, 09:53 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Should be able to use stock valley with dod delete plugs. I would change all 3 lines...some have gotten away with reusing the lines and some have not.
Old 07-06-2022, 10:01 AM   #4
cjperformance
cjperformance's Avatar
They are crush fit for the sealing... thats why they have to be replaced...so... imo replace them. I did. Sucks to spend a couple hundred on fuel lines, but a fuel leak is not worth the risk. Same concept as reusing torque to yield bolts.... can you? Maybe... but not a good idea.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 07-09-2022, 09:46 AM   #5
zepol9
Thank you so should run just the lt4 feed pipe ? Or replace it all with lt4 lines
Old 07-09-2022, 12:01 PM   #6
cjperformance
I dont recall if the hard lines were designated lt1 vs lt4... the line that goes over the engine came with my dsx flex fuel kit. The s bend hard lines i think are the same regardless. I used the dual 45 deg bend hard line coming from the pump to distribution block. Maybe this will help? https://www.camaro6.com/forums/showp...14&postcount=5
Old 07-10-2022, 09:41 AM   #7
KingLT1
KingLT1's Avatar
There are different hard lines. I changed the one coming from the HPFP --> Injector rails to the LT4 ZL1 unit since it has less of a bend and suppose to flow a little better vs the LT1 that has a 90 degree bend. I also used the LT4 feed line that doesn't have the check valve.
