Old 06-20-2022, 06:38 PM   #1
Zboy136
Drives: Red Hot 17 1LE
In need of a driveline expert
If anyone knows one, please send him this way, I need help for my car.
Zboy136 is offline   Reply With Quote
Old 06-20-2022, 07:11 PM   #2
cjperformance
cjperformance's Avatar
Folks usually post issues on this board for help
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-20-2022, 07:18 PM   #3
Zboy136
My issue is with the drive line, after hitting a messed up part of the road, not a pot hole, but for lack of knowing exactly what it was, other then a messed up part of the road. I've been experiencing a drive line vibration.
At highway speeds, its so bad, you can actually hear a rotational noise if you put your ear by the touch screen.
Ive replaced so many parts ive exhausted anything I can think, and the local dealerships are no help.
Parts replaced
Brand new tires just put on and road forced balanced.
New rims, stock 1le official rims from chevy
Both halfshafts
Both hub assemblies
switched out the stock driveshaft for a 1 piece aluminum
The only thing I can think of at this point would be differential, or something in the transmission area?
Old 06-20-2022, 07:31 PM   #4
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Check your motor mounts to see if they are lose. It can cause a vibration down the chain.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 06-20-2022, 07:53 PM   #5
Zboy136
Ok theres a start ty for the suggestion black
Old 06-20-2022, 08:01 PM   #6
Zboy136
Also wanted to add, the car displayed this vibration when put on a dyno, which had me thinking it was coming from the rear, it was enough vibration you could feel it in the floor standing near the dyno.
But the motor mount suggestion definitely has me thinking
Old 06-20-2022, 08:16 PM   #7
MightyBobo
MightyBobo's Avatar
Drives: 2022 VOM 2SS 1LE M6 Camaro
Could have busted a tire belt, which will definitely experience vibration issues at speed.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251)
20211120 - 1100 --- 20211207 - 2500
20211208 - 3000 (TPW: was 20220103, now 20220124)
20211220 - 3400 (TPW: 20220110)
20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle)
20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223)
20220212 - 4800 --- 20220216 - 6000!
2024 Silverado 1500 LTZ 3.0 diesel
MightyBobo is offline   Reply With Quote
Old 06-20-2022, 08:20 PM   #8
Zboy136
All tires were just replaced, to the stock goodyear eagle f1's about a week ago.
Old 06-20-2022, 08:53 PM   #9
BlackbeastSS2
Also to try and pinpoint the area of the vibration you can rev your engine up to the point where you feel the vibration. At this point push your clutch in, if the vibration does not go away it’s more likely in the engine rotation. From balancer to crankshaft etc. Hope you find out where your vibration is and fix it.
Old 06-20-2022, 09:22 PM   #10
Zboy136
It starts to come in at 45mph and on the highway if i push the clutch i continue to feel it.
Old 06-20-2022, 09:43 PM   #11
Alan47717
Drives: 2022 1LT RS 2.0t/6spd
Does it just get worse as you go faster? Is the vibration the same if you speed up and then coast down to below 45 mph? If it's the same regardless of load it isn't engine or engine mount related.
I think you have go back to the "messed up" road issue. Something being damaged or bent sure seems suspicious. I assume you have had a four wheel alignment done by a reputable shop.
Alan47717 is offline   Reply With Quote
Old 06-20-2022, 09:47 PM   #12
Zboy136
I did and they said it was only slight out it wasnt too bad.
It comes in at 45 but definitely gets worse and as i said up above u can actualy hear something out of balance by the radio screen if u put your ear there. at 70 its pretty apparent.
I feel it mostly in the seat and in the floor board but there is a slight vibration in the wheel as well
Old 06-21-2022, 06:07 AM   #13
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
What about your brake rotors? Not sure how they could get damaged if you hit something in/on the road but maybe?
Spaceme1117 is offline   Reply With Quote
Old 06-21-2022, 08:21 AM   #14
cjperformance
Not many places have these, but what about trying an on car wheel balance? It has to be something spinning at road speed from your description. Getting the car up in the air and getting the wheels in motion might help identify something. Put a dial indicator on the rim and check for runout (wobble), while slowly/manually spinning the tire. Do this both on the side of the wheel/rim (axial runout if i recall correctly) , and also on the tread (radial runout). Same can be done for other spinning components. Sounds like most spinning components have been replaced... so id focus on measuring what those spinning components mount into.... check runout on your new halfshafts for example. You arent checking the runout of the shafts, but rather the bearings they attach to. Then spin and check driveshaft, etc...
Could also be damaged suspension or non rotational parts. Example a damaged/loose/broken suspension link bushing will still allow any otherwise normal vibration to become more pronounced due to driveline not being properly constrained.
These are just general observations from my past experiences on a wide variety of cars.
Doing an on car wheel balance should help narrow down to wheel/hub/suspension area vs other driveline vibration.
