Old 06-20-2022, 08:51 AM   #1
paradigm
Drives: 2022 Camaro 1SS 1LE
Just got my 2022 Camaro 1LE 6-speed - break in procedures
Just picked up my 2022 Camaro 1LE 6-speed on Friday after waiting 6 months from the order date. It was supposed to be cancelled (color constraint I believe), however it ended up squeaking by and I took delivery on it. I also had a base mustang GT on order which arrived on the same week, but I went with the Camaro instead.
Is there a break-in procedure to follow for the engine? Keep it below 3000 rpms? How many miles before changing out the oil for the initial break in?
Photos of actual car:
paradigm is offline   Reply With Quote
Old 06-20-2022, 09:17 AM   #2
David Gordon
Drives: 2018 Grandsport Corvette
I have had many sports cars and I broke everyone in like I stole it. Never one time did it break something.
With the exception of my 2001 SS M-6, I added drag radials and broke the clutch.
2022 Orange ZL1
4/07/22 7-01-22
Past
2018 Gransport
2018 GT Premium
2009 ZO6
2008 Z-51 Vette
2001 Stroked/ blown C-5
2001 SS
1998 SS vert.
2020 Range Rover V-8
2021 Ford F-150 Platinum Powerboost
David Gordon is offline   Reply With Quote
Old 06-20-2022, 09:26 AM   #3
cariboocreek
cariboocreek's Avatar
Drives: 2023 Corvette C8
I believe the manual covers it nicely. You are going to hear a wide variety of opinions from baby it to trash it. Your money, your car. Rings are seated by the time you hit 100 miles. Diff is another story. Also break in is not what it was in the 70's. New metals, new tech have changed and simplified break in times and methods.
Change you engine oil, your diff and tranny fluid at 500 miles. Do them again at 1500 miles.
2023 Corvette C8 70th Anniversary Edition
———Gone But Not Forgotten———
2022 Camaro ZL1 Convertible (Never Delivered and won’t forget)
2019 Camaro SS Convertible
2019 Corvette Grand Sport Convertible
2013 Corvette Grand Sport
2013 Challenger SRT 392
1995 Camaro Z28
cariboocreek is offline   Reply With Quote
Old 06-20-2022, 09:29 AM   #4
ZPirate
ZPirate's Avatar
Congratulations! Welcome to the 1LE club. I think many of us have followed the guidelines in the Performance supplement regarding break in. Keep it below 4K rpm for the first 500 miles, then change the oil at 500. Then change the oil again at 1,500 miles. I'm about to reach the 1,500 mile mark and will probably change the oil this weekend.
Others will say don't worry about break in and drive it like you stole it. I prefer to by more cautious with a brand new engine. Oil changes are relatively inexpensive in the grand scheme of things. But ultimately its up to you how you to decide.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 06-20-2022, 09:46 AM   #5
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
I’m curious, how old are you? I only ask because I’m always in awe of of these kinds of questions. I can’t imagine making such a big purchase without reading the owners manual. To my surprise it actually seems quite common.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
Aaron07 is offline   Reply With Quote
Old 06-20-2022, 10:20 AM   #6
PJS57
Drives: 2023 Cadillac CT4
Really good thread on all this here:
https://www.camaro6.com/forums/showthread.php?t=531978
I hear all sorts of things from break in doesn't matter to what cariboocreek said with the very conservative 500/1500 mile maintenance. On my 22' 1LE I just went by the manual, and have not had any issues. Changed the diff fluid @ 1500 miles and it was pretty gross so I wouldn't skimp on that.
As for the trans specifically, I kept it in auto rev match mode for most of break in as I try to learn heel/toe with this pedal box vs. what I was used to on my Mustang GT. I'm thinking it's easier on the synchros than missing the perfect rev match because my feet aren't calibrated to his pedal layout yet.
For trans fluid, I had a T56 Magnum in my S197 mustang and changed the fluid @ 1500 miles. It looked brand new when I drained it so I'm not even going to bother with it on this car for a while given the gear cluster is the same in the TR-6060 & T56 Magnum. Might consider doing it this winter after a couple track days though.
PJS57 is offline   Reply With Quote
Old 06-20-2022, 10:46 AM   #7
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Everyone is going to have their opinion on this, but I followed the manual.
And it states:
For the first 1500 MILES, not 500, not 100, not 10.
. Avoid full throttle starts and abrupt
stops.
. Do not exceed 4000 engine rpm.
. Avoid driving at any one constant
speed, fast or slow.
. Do not drive above
129 km/h (80 mph).
. Avoid downshifting to brake or slow
the vehicle when the engine speed
will exceed 4000 rpm.
. Do not let the engine labor. Never lug
the engine in high gear at low speeds.
With a manual transmission, shift to
the next lower gear. This rule applies
at all times, not just during the
break-in period.
(Continued)
Caution (Continued)
. Do not participate in racing events,
sport driving schools, or similar
activities during this break-in period.
. Check engine oil with every refueling
and add if necessary. Oil and fuel
consumption may be higher than
normal during the first
2 414 km (1,500 mi).
. To break in new tires, drive at
moderate speeds and avoid hard
cornering for the first 322 km (200 mi).
New tires do not have maximum
traction and may tend to slip.
. New brake linings also need a break-in
period. Avoid making hard stops
during the first 322 km (200 mi). This
is recommended every time brake
linings are replaced.
. Should the vehicle be used for racing
or competitive driving (after break-in),
the rear axle lubricant must be
replaced beforehand.
Christian1LE is offline   Reply With Quote
Old 06-20-2022, 10:52 AM   #8
Edward Paul
Edward Paul's Avatar
Drives: LT1
My main rule for a new engine is Not to get stuck in traffic.
Keep the air moving. I'm in Florida and it's 99 right now.
I break in at night when the sun is down, and the roads have less idiots on them.
Edward Paul is offline   Reply With Quote
Old 06-20-2022, 10:59 AM   #9
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Don't stay a same rpm long . Vary rpm.
Gen6cyl is offline   Reply With Quote
Old 06-20-2022, 11:03 AM   #10
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
And it states:
stops.
129 km/h (80 mph).
break-in period.
(Continued)
Caution (Continued)
I followed this. I autocross and a GM tech friend said get the miles on it (1500) before hammering it. It works. I had oil consumption of 2/3 qt in the first 2200 miles, another half qt by 3300 and none since and have 8900 on her now. And that’s with high rpm 2nd gear only and hitting rev limiter in autocross.
Maybe as I was lucky to have a hand built corvette engine in my car haha
VR Baron is offline   Reply With Quote
Old 06-20-2022, 08:47 PM   #11
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
Did the 2nd oil change and rear diff at 1500 miles at the dealer. I watched him drain the diff, it was gross. Then hammered it ever since.
pzoom is offline   Reply With Quote
Old 06-20-2022, 09:26 PM   #12
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Follow the break in recommendation for your Camaro in the owners manual and it will be good to go. Oh by the way, congratulations and a good looking 1LE!��
Old 06-20-2022, 09:28 PM   #13
RegularJohn86278263789
Drives: 2008 Corvette Z06, 1991 Mustang 5.0
Just came here to say that car is absolutely beautiful. Best color for the 6th gen
RegularJohn86278263789 is offline   Reply With Quote
Old 06-21-2022, 09:39 AM   #14
paradigm
And it states:
stops.
129 km/h (80 mph).
break-in period.
(Continued)
Caution (Continued)
Thanks for this.
And thanks everyone for their advice and tips. I will follow the manual. I should have consulted it first prior to posting. This is my first new car I have ever owned, waited a long time to buy a new car and given current market conditions, used car values don't make sense to buy used anymore, to me at least.
I definitely need to get side skirts to help with rock guards.
How much are you guys paying for PPF for the front bumper?
Any other tips on protecting the car from the elements?
How many miles are you guys getting out of the stock 1LE goodyears? I am thinking of swapping for Contintental DWS06 all seasons, as I will not be tracking the car and prefer to sell off the Goodyears as they are near new.
