![]() Drives: '18 SS 1LE Join Date: Jun 2021
Help Confirming 3 bar map bar Breakout Tune Updates for Procharged Car
I recently added a baro breakout and 3 bar map to my procharged 2018 SS 1LE (otherwise stock) and need some help verifying the changes that I made to the tune. Can anyone verify the changes they made when they did this?
I'm using a ACDelco 3 Bar Map #12592525 I changed Sensor config from NA-MAP to NA-TIAP Estimated Max to 200kpa Map sensor linear to 312.50 kPa Map sensor offset to -11.31 kPa |
I believe that is correct.
