Old 06-14-2022, 05:04 PM   #1
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
Need Help Identifying Transmission Leak
Hey y'all
Last night I was driving back from the airport with extreme spirit. Empty roads, lots of speed...
An hour later I get home and when opening my trunk I noticed my car was covered with a sticky fluid. I looked under the car and saw the bottom of the car coated in some liquid.
As soon as daylight hit today, I drove the car up a set of ramps and I can see that it's red fluid that starts 2/3 ways back of the transmission and it's gone as far to soak everything behind it.
I did get my torque converter replaced a year and a half ago because of the transmission shudder issue but the TQ is at the front of the transmission, right?
Any ideas or guesses as to what the source of the leak might be? I'm taking the car into the mechanic that fixed the TQ last time but I'm looking for some insight to help me sleep the night before they see the car. Am I looking at hundreds or thousands of dollars?
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 06-14-2022, 05:35 PM   #2
cjperformance
cjperformance's Avatar
Could be oil pan, cooler lines, fill or drain port. None of that prob too bad. Worst case, cracked case... then it's a new tranny. Clean it all up and just trace the leak from there. Doubtful it's the tq conv as you said it's at the front.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-14-2022, 06:14 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
You can reach the rubber fill plug from passenger side. That plug is 2 pieces. The center portion acts as an expansion to keep the main plug attached. It’s a quick check to see if both pieces are there and properly installed.
Old 06-14-2022, 06:27 PM   #4
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Sure looks like you’re missing the front center pan bolt.
Sweptwing is offline   Reply With Quote
Old 06-14-2022, 06:43 PM   #5
Trochoidal
I missed that and you’re right it’s missing. Good eye!
Old 06-14-2022, 07:02 PM   #6
cjperformance
No fair! I dont think there were pictures when i replied.
Old 06-14-2022, 07:03 PM   #7
cjperformance
People are prob stealing trans pan front bolts now instead of cats.
Old 06-14-2022, 07:30 PM   #8
Sweptwing
Sweptwing's Avatar
Yep! Hopefully a new bolt and a re-torque of the trans pan and he should be in business.
Old 06-15-2022, 12:44 PM   #9
Giri
Good eye guys! I assume the transmission place forgot to put that bolt back in when they fixed the TQ in 2020. I just wonder how the bolt missing would cause a problem years down the line. There were no leaks before yesterday and the only thing different about yesterday was how hard and fast I drove the car.
Here's two short videos I shot of the transmission. It's pretty obvious that the damage actually started at the top front of the transmission - Torque converter? Whatever it is, the pressure shot transmission fluid UP and towards the engine (black plastic cover in the beginning of the vertical video)
https://youtube.com/shorts/Us_oCuCeXvM?feature=share
https://youtu.be/L2mB1aS27Mc
Old 07-02-2022, 08:50 PM   #10
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Unbelievable. Looks like 2 bolts missing. I'd be pissed if I was you. That shop would be getting an earful over this. Piss poor mechanics do that sort of thing. Seriously.
Here's another question, are you sure they didn't snap off the bolts? If so you'll have to back them out too!
Dynamical is offline   Reply With Quote
