![]() Drives: 16 2SS Join Date: Feb 2017
Charging system failure could be belt tensioner.
I threw a charging system failure check engine light and thought it was probably my 6 yr old battery. Actually, the serpentine belt tensioner blew out and the belt was slipping. Heads up, if your charging system fails pull over in case it is the tensioner as the belt also spins the water pump.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
Can you explain the photo a bit?
The rubber boot area looks different old vs new. Did spring break inside old unit? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i had my battery replaced around 4 years in under warranty and i had my tensioner replaced about 6 months later under warranty only 2 real big problems i ever had with my camaro
![]() Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
I replaced my serpentine belt tensioner quite early on, at about 8k miles. I noticed that oil was leaking out of the rubber boot, but I didn't have any other issues. Now at 25k miles and there are no visible leaks yet.
The one to the right in the photo looks like a new design. (EDIT): Link to old thread: https://www.camaro6.com/forums/showthread.php?t=558883 |
![]() Drives: 2018 ZLE Join Date: Jul 2014
Could you hear the belt slipping or see any damage to the belt?
Wondering if I have the same problem, but no evidence |
