Old 06-06-2022, 12:35 PM   #1
nick_casper
nick_casper's Avatar
Drives: 16 2SS
Is E15 OK with a supercharger?
I run 10% ethanol because it is what the car was tuned on. With 15% ethanol on the way will it be safe to run with the same tune? Would we be better off running ethanol free or E15 with an E10 tune?
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 06-06-2022, 01:37 PM   #2
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Really depends on how aggressive the tune is and if your E tables are turned on. Tuners here can offer more.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 06-06-2022, 01:46 PM   #3
timesublime
Drives: Waiting for the 2SS
E15 is ~88 octane
2023 2SS 1LE M6 BCD
1100 6/6/22 3400 2/17/23 TPW 2/17
timesublime is offline   Reply With Quote
Old 06-06-2022, 01:47 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No unless a flex sensor is installed and the tune is set up for it. Then yes up to the point where you run out of fuel system. If stock fuel system is still in place then back to No because stock fueling is barely adequate for E10 with boost.
Old 06-06-2022, 01:48 PM   #5
KingLT1
KingLT1's Avatar
Originally Posted by timesublime View Post
E15 is ~88 octane
Not if it's 93 octane blended with 15% Ethanol.
Old 06-06-2022, 02:50 PM   #6
timesublime
E15, often sold at the pump as Unleaded 88, for its octane rating, can safely be used in all cars, trucks and SUVs from 2001 on.
2023 2SS 1LE M6 BCD
Old 06-06-2022, 03:19 PM   #7
nick_casper
Drives: 16 2SS
The E10 here is available in 91 octane. Hopefully we can still get E10 through the summer.
Old 06-06-2022, 03:28 PM   #8
mariojas
mariojas's Avatar
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD
Originally Posted by nick_casper View Post
The E10 here is available in 91 octane. What are you all going to use if E15 is all that is available after Bidens executive order.
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover
Charger sold! Better to sell, than waiting to be stolen...
mariojas is offline   Reply With Quote
Old 06-06-2022, 03:29 PM   #9
KingLT1
KingLT1's Avatar
That's because it's mixed with low octane pump fuel. I agree not to use pump E15 If it's labeled 88 octane. Ethanol basically adds octane to the base fuel it's being blended with.
Old 06-06-2022, 03:54 PM   #10
cjperformance
cjperformance's Avatar
Depends on your tune.
#1 The octane would still have to meet or exceed what's recommended... for a supercharger running any real boost, I would think anything less than 91 octane is "bad". Even 93 is "bad", lol.
#2 Even if the octane is right... an extra 5% eth in E15 is going to make it run slightly leaner than E10.
Bottom line, run what the tune is designed for, if you have flex fuel and the octane is sufficient, then you should be ok.
If the octane is too low it's asking for trouble.
If the octane is ok, but you dont have a flex fuel tune... then it's going to run a little leaner, which is especially bad for a sc. Enough to cause problems? Don't know, depends on your setup.
With no flex fuel, the eth free is prob better because it will tend to run richer. It's counter-intuitive because it will run richer, but consume less volume of fuel.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-06-2022, 04:00 PM   #11
timesublime
Re-reading the mandate, and from what I gather it only applies to e15-88 octane. The mandate allows it to be sold in the summertime in locations that typically disallow e15 in the summer months. Nothing in there about blending other grades to 15%.
2023 2SS 1LE M6 BCD
Old 06-07-2022, 10:35 AM   #12
nick_casper
Drives: 16 2SS
I hope this is the way it goes. I work in the O&G industry and we are hearing rumblings of major fuel shortages this summer. I think I'll use eth free over E15 if those are my only choices.
