![]() Drives: Black 2022, ZL1, Hurst M6 NPP Join Date: Feb 2010
Performance Question
I am wanting to add the Roto Fab CAI but not sure which one to go with. Any advice welcome. Also have thought about changing the top or bottom pulley. Can someone direct me on which way is best? Thanks.
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Regular Rotofab if you are keeping stock throttle body. Bigger throttle body (103) needs a tune and fits the Big Gulp CAI (and require tune).
Leave the pulleys stock unless you are also doing cooling mods (expansion tank, heat exchanger, ethanol, etc). |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You get more performance from a tune than a CAI with or without a tune.
A CAI is going to net you more supercharger whine with little hp/tq gain. The stock airbox is very efficient well over 700rwhp. |
#4 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Do you have any other plans or goals for the car? Best to layout a plan and goal so you dont have to replace too many parts later on as you start doing more mods. As for you main question... CW3SF hit the nail on the head.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi |
Performance Question #2
Many thanks to all who took the time to reply and their good and helpful advice.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '20 ZLE Join Date: Jun 2020
If you're just cruisin around the Odessa area, but not doing any road course or drag strip racing or at least very little, then buy a RotoFab and put a 5 or 10% lower pulley on it. Probably wouldn't even need a tune. First confirm the diameter of your lower pulley. I believe it is 8" but you should check it.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
#7 |
![]() ![]() Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
Are there ways to modify the stock air box just to enhance that sexy blower whine? That's the main reason I want to do an intake (not for power at stock levels). Can you get more sound without spending the hundreds for the intake setup?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
#8 | |
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Also, some have removed the damper plate from the supercharger lid. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Side note the 103 doesn't really do anything unless you port the supercharger. Opening isn't big enough to utilize it.
2016 NFG 1SS A8
#10 |
#11 |
I disagree. Mine made 723 wheel with RotoFab and OEM SC/TB.
'20 ZL1 1LE A10.
#12 |
Yea, I've seen a couple youtube clips where they did that, but it didnt seem to make a very noticeable difference.
#13 |
#14 | |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
i got a used rotofab for cheap and made 13hp and 7tq back to back and didnt just kill a thousand upon thousand dollar warranty!! worth it? sure, cheap and a little noise. |
